6 members (Graham, G4FUJ, Snowden, Montegue, Rastus, Image, JMcL),
151
34
Topics49,904
Posts838,063
Posts: 27,840 Likes: 764
Posts: 27,840 Likes: 764 |
So Morgan's do have wooden chassis afterall. All those experts who come up to my car & tell me that have been right all along
Posts: 2,361 |
I get mine made and are fully adjustable
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
Has anyone developed a Watt's Linkage for the Morgan? The Holden V8 racing cars in Australia used to have a live axle with a Watt's Linkage.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Watt's a watt's linkage  ??
Richard 1976 4/4 4 Seater
To quote Wikipedia Watt's linkage (also known as the parallel linkage) is a type of mechanical linkage invented by James Watt (19 January 1736 – 25 August 1819) in which the central moving point of the linkage is constrained to travel on an approximation to a straight line. It was described in Watt's patent specification of 1784 for the Watt steam engine. It is also used in automobile suspensions, allowing the axle of a vehicle to travel vertically while preventing sideways motion.
http://en.wikipedia.org/wiki/Watt's_linkage
Must be true I guess
Thanks John - I could not resist the question!
Posts: 1,947 |
The advantage of a Watts linkage over a Panhard rod is the former keeps the axle movement in pretty much a straight line up and down, whereas a Panhard rod allows the axle to describe an arc, ie a curved path.
To my mind, the path described by the axle is only really an issue when the allowable suspension movement is great, ie an off road or rally car but you pay the penalty of carrying more weight and of increased maintenance as there are twice as many joints.
Posts: 655 Likes: 12
Posts: 655 Likes: 12 |
Beamish Morgan describes the A-frame alternative. Harald
Harald +4 4-seater 2008 Squadron Blue
Posts: 1,947 |
It's an expensive alternative, even if you can persuade them to make and fit one.
Posts: 238 Likes: 3
Posts: 238 Likes: 3 |
If you want a Watts linkage , Scimitar cars used to have this arrangement , they also used Salisbury axles with a special cast cover to accommodate the pivot point not sure if it will be straight swap for the Morgan tin diff cover tho'
1999 Morgan Plus 8. 3.9 .... 1961 Alvis TD21 Series1 3 Litre Auto....
