2 members (Gonze, Image), 242 guests, and 56 robots.
+8Rich 79
Luddite 50
Posts837,932
#141010 19/06/13 04:10 AM
Darmont Special 3 Wheeler
A 1923 Darmont Special 3W spotted last week-end. Some castings with the Morgan name moulded in. ;-)
9 Comments
Tasty but the engine seems small.
Can someone on TM identify that engine? It seems to have 2 x spark-plugs per cylinder, but with only one on each cylinder connected!
Bud
budster
Bud
4/4 "Stanley"
Darmonts were made under Morgan Licence in France - so its probably a French engine - I cannot recognise it as English.
It was quite common to have two plugs per cylinder - just for ease of change over in case of failure! spark plugs were no where near as reliable in those days!!
hope this helps!! cheers
Neil
Here's the model plate off the one I posted elsewhere. Darmont Plate
John, I suppose the engine looks a bit small because it's a sidevalve, without the cylinder height of an OHV. Gerry.
Gerry
I think it looks like a Blumfield engine.
1090cc
http://morgan3w.de/ >>engines.
Greetings Jens
Originally Posted By Jens
Looks like a Blumfield engine.
1090cc
Greetings Jens
Thanks thumbs
Bud
budster
Bud
4/4 "Stanley"
Thanks for the engine identification. Darmont has equipped his 3 Wheelers with Darmont engines which were copies of the water cooled ot air cooled JAP (normal model) or Blackburne engines (Special model).
Perhaps also as this car may show some Blumfield engines as they were also fitted to Morgans I understand.
Quite possible the car has had the engine changed anyway.
I don't think it's meant to be a two spark plug per cylinder engine, just that the unconnected one is filling a hole! Got a feeling that the plug inserts are removable, and you could extricate the valves without removing the head.
