1 members (+8Rich), 284 guests, and 32 robots.
+8Rich 95
John V6 49
Posts837,992
rockabilly john
Sukram Offline OP
Morgan 4/4 with Ford CVH Motor and Electronic Ignition Systems from 1985.
A had a failure in my system, after some raining days and then very warm weather, the motor is suddenly running low Rpm and has no power, aim not able to run.
This happens on 3 Year 2 times, after replacing the Electronic parts problem is gone.
I want change now this system, if somebody has an advice or ideas.
Thanks for help
Don't Worry, Be Happy
Morgan 4/4 1985 2,0 Zetec
BMW R1200 GS
Triumph TR140
My starting point would be to speak with Burton Power (www.burtonpower.com) - no link to me just been pleased with the service that they have provided me (albeit on my Kent Engine)....
I seem to remember there's a vacuum hose on the CVH that can perish on the front left of the engine as you look from the front of the car that leads to the same symptoms.
1972 4/4 2 Seater
CBY Offline
Good evening,
It seems on the photo there is no hose connected to the vacuum device.
Regards
Regards
2005 PLUS 4
Sukram Offline OP
Do you have more details please?
The Vakuum is coming from the carburator !
BMW R1200 GS
Triumph TR140
CBY Offline
The vacuum is coming from the carburator through a small hose which is normaly connected to the pipe indicated by the red Arrow. This round device is part of the vacuum timing advance and includes a rubber diaphragme which moves by difference of pressure.
Regards
Regards
2005 PLUS 4
Sukram Offline OP
Vacuum is working, ... i suck 
Aim on holiday now, will finish the work in 2 weeks,
But perhaps I could order new electronic system if somebody advice which is ok for CVH or Ford 4 cyl.
BMW R1200 GS
Triumph TR140
Sukram Offline OP
BMW R1200 GS
Triumph TR140
