8 members (Paul F, andymog1, BLUE+4, SailingTom2, Rastus, ChrisConvertible, Image, Simon),
241
Topics49,908
Posts838,121
Posts: 41 |
Can anyone advise the wire colour of the headlight main beam circuit on a 2009 4/4 to which I should connect to a switch or relay. Also any ideal of the best place to expose and make a connection to this wire? Your help would be appreciated.
Jack
Posts: 28,911 Likes: 354
Posts: 28,911 Likes: 354 |
Should be blue with a white stripe. PM me your email address and I'll send a copy of the wiring colours (admittedly from around 1982, but the colours don't change). Above colour code assumes Morgan have followed the colour charts of course - test the lead before fitting. Do fit a relay (via a switch - your dip/main column switch will not be strong enough to cope with the current the drive lamps will need).
Cheers,
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
Should be blue with a white stripe That was still the case according to the 2005 wiring diagram.
Posts: 41 |
Thanks,Graham and Peter for you help.
Too hot to look at it today, being 39 degrees C in the open this afternoon, but enjoyed a nice run to Cheltenham this morning.
Cheers,
______________________ Jack 2009 Black 4/4 sport.
 I took the bus into town, but then I'm still reworking the wiring... Cheers,
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
How's it going Graham - any photos?
Richard 1976 4/4 4 Seater
In this heat Richard, its stalled for the moment. I'll get a few pics when I've opened the damaged section of loom. Still working out whether to retain the original circuits but with a few more fuses (which will be quicker to implement), or whether to rewire properly, so the increased fuse box capacity protects all circuits as a later car would be wired - that will take longer to sort though. That has to be favourite I think. Until that decision is made, I'm not buying any parts.
Cheers,
...if it is worth doing....
I would go for the latter too...more rewarding once complete too.
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
In my 2002 4/4 I fitted spots to an existing spare bullet that was near the overider as this was live on main beam so assume that it was integrated into the loom for such a fit. Is there not a spare cable nearby.
I expect wrongly that if there was a cable then the relevant switch on the stalk (the Land Rover Freelander style) would be adequate to take the main beam and the spots...
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
In the Freelander, if you add driving lights, the factory loom that comes with the extra lights includes a relay (from memory...).
