8 members (thelastgizmo, Luddite, JohnHarris, Mike D, Craig Jezz, DJC, +8Rich, Montegue), 275 guests, and 42 robots.
+8Rich 94
John V6 49
Posts837,993
rockabilly john
#144945 16/07/13 07:01 PM
LB is at RPM for some remedial work, and I'm told the front brakes need new discs and pads because they're corroded! My question is: what sort of crap parts are they fitting that need replaced after 2 years & 13000 mile??? scared
To say I'm annoyed is an understatement...
2011 +4 'LB' Indigo Blue, Heron trim
Saab 9-3 1.8T Sportwagon
Mike Carter #144950 16/07/13 07:42 PM
Not impressive.
+8 4.8
Neilda #144951 16/07/13 07:47 PM
I'd be getting a second opinion myself! What sort of symptoms were you getting when using the brakes?
Jays #144952 16/07/13 07:53 PM
Me too. Ask to see the old discs and pads on the car.
1972 4/4 2 Seater
Jays #144954 16/07/13 07:56 PM
I suspect it also depends upon the type of environment that the car is mainly used in. Certainly, coastal areas tend to cause more corrosion on any cars and also the liberal use of salt in the winter does not help.
I am surprised that with the type of mileage and age of car, that it has got that bad that it needs discs and pads. I would want to see for myself before committing to that type of expenditure.
Neil
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
NeilM #144955 16/07/13 08:01 PM
Do you often put the car back in the garage with wet discs....i.e. not dried them out after washing the car.
Just a thought...
Jaguar F-Type V6s roadster
2009 Harley Davidson XR1200
1986 Honda VFR750F (RC24)
NorthernMogman #144978 16/07/13 09:24 PM
I'm sure OZ 4/4 will be along soon as he's fastidious about Morgan brakes on the newer cars.
Mike Carter #144989 17/07/13 01:41 AM
Are they Caparo brakes? scared
OZ 4/4 #145001 17/07/13 05:02 AM
They will be Caparo calipers. I've suffered from a sticking pad for ages whenever the car has been wet. Not that easy to dry off the brakes when it is raining! Williams have changed the pads to Mintex, as well as fit Aeroquip hoses and I'm hoping that the new pads don't stick. Luckily my discs were ok at 12,500 miles.
It'll be interesting to see how much RPM charge. EBC green pads are around £35 for full front set and their replacement discs around £120 a pair. I suspect Morgan charge a lot more!
Mike Carter #145019 17/07/13 06:45 AM
Mike - see PM.
