5 members (DavidR, +8Rich, John Winn, Ian Wegg, Clipper), 284 guests, and 30 robots.
+8Rich 94
John V6 50
Posts837,996
rockabilly john
Mike Carter #145058 17/07/13 10:09 AM
E
E
The discs on mine are fine after 14000 miles, some corrosion to the outer edge but thats all. Winter use when there is salt on the roads may well corrode the discs faster.
1989 911 Porsche Carrera
Land Rover Series
Defender 90 SW
Edgar 1969 4/4 #145075 17/07/13 11:54 AM
The discs on my 2011 plus 4 had a slight warp at 8,000 miles.Kick back at low speeds ,
This was deemed to be within tolerance on my 11500 mile service whilst under warranty.
Peter.
Aero plus8 50th Anniversary.
MR11MOG #145131 17/07/13 05:59 PM
I've droned on at length about how on my Morgan, one face out of four is suffering a covering of light rust. A lot depends on how much use and what type of use. If you're light on the brakes they will never clean completely. I do try to give the Roadster brakes a good work out occasionally, so a few heavy applications keep the discs good in summer. Mine are not originals anyway, because owner 1 went totally greenstuff on the front, but the old discs came with the car and after less than 5000 miles had the imprint of the pads in rust on all four faces.
DaveW #145133 17/07/13 06:04 PM
I have just had my MX5 front pads and discs replaced after 15 years of use. One face was slightly rusty and it turned out to be a lazy piston. Looks like new now and cost about £200 to have done.
Neil
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
Mike Carter #145144 17/07/13 07:03 PM
Rust never sleeps. Drive any car on salty winter roads and put it away for a few months and see what happens to the rotors. To avoid the problem one would need stainless brakes .
Harald
Harald
Max5 #145147 17/07/13 07:25 PM
Thanks for all the advice & tips - sadly, I can't do any brake-bashing as the car is 150 miles away at RPM. In fairness, I should perhaps give a bit of background: the 'remedial work' is being done under warranty, fortunately, as there's 3 issues: Corroded windscreen pillars, non-working speedo & washer pump. The brake issue came up up as a result of the speedo problem, the sender on the OSF wheel had rotted away...
The lesson I have learned is : outdoor Carcoons are A WASTE OF MONEY! Won't be using THAT again! swear
BTW the cost of the brake rebuild is £350 for pads, discs, springs & labour @£70 per hour,inc. VAT. I'll live with it.. spend
2011 +4 'LB' Indigo Blue, Heron trim
Saab 9-3 1.8T Sportwagon
Mike Carter #145150 17/07/13 07:49 PM
I have not had problems with my +4 but I have with my camper van. I live by the sea in Cornwall, so have salt in the air and the van is out all the time. It is on its third set of front discs. The backs do not suffer as they are protected by the bodywork. I now use wheel covers that you see on caravans. It protects both wheel and tyre and my discs are like new. They were about £15 each on ebay, and are secured to the wheel by elastic over the back of the wheel.
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
titus #156006 17/09/13 06:51 PM
JJW Offline
Can anyone suggest a brand/supplier/part number for replacement pads for the caparo calipers on a 2010 roadster?
I think I have glazed mine frown Regards, JJW
JJW #156015 17/09/13 07:24 PM
Formerly known as Aldermog
Mintex, contact Williams Morgan.
I've got their "Roadsport" pads, not for road use (Doh!)
More feel, more progressive but squeak a bit when cold.
Peter J #156160 18/09/13 03:37 PM
Sand the glaze off and put the pads back in, and brake harder! Glazing is usually caused by under-use. Or get softer pads, not racing ones.
Fjemog
1993 Plus 8
