2 members (Taffmog, DaveK), 194 guests, and 40 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,149
Georgetoad, woolfie
Every so often someone asks about cleaning mohair and vinyl hoods. I posted the item below on another thread some months back and I thought it was time to report back.
In all I have found the products very easy to use and the protection seems to work well. I placed some cardboard sheets over the glass and paint to protect them from overspray, though the Protectant really seems quite harmless to paint. Any overspray I wiped off straight away as recommended. After a while when the product seemed dry I noticed a mist of tiny droplets still remained on the surface and I simply wiped over the mohair with my hands to distribute them into the surface of the weave. I'm not sure if that was the right thing to do but it seemed to work (then went and washed my hands).
I have now washed the car several times since applying the Protectant and there is no sign of any ingrained dirt or stains. Even after being caught in a really heavy rain storm the top seemed quite clean so the Protectant seems to have a water and dirt repellent effect.
The Cleaner will not remove tree gum but I have found that a few drops of tea tree oil will dissolve the gum and the tea tree oil is so light that it just washes off. It works on painted surfaces too though I suggest trying it on a "safe" place first just to be sure there is no damage. Naturally any protective coatings or wax would need to be re-applied to the area. In my case I had some spots of gum on the car and one on the hood before I applied the Protectant and I have not had any since so I can't say if it helps to stop the gum from sticking.
I believe Haartz are the manufacturers of the mohair material. This is their page on cleaning.
http://www.haartz.com/en/consumer_info/cleaning/cloth_top_cleaning.asp
As you can see they recommend RAGGTOPP™ Cleaner and RAGGTOPP™ Protectant.
http://www.wolfsteins.com/product-all.htm
I ordered a RAGGTOPP Convertible Top Fabric Care Kit from the German distributor. It came with a brush in the kit to use with the cleaner. I have not used it yet so I can't comment on it. I will use it in the spring when the weather is a bit warmer.
They also have vinyl care products. Their distributor page is http://www.wolfsteins.com/distributors-2009.htm click on the flag to get the various countries.
Thanks for the report, Peter. I have been looking to buy something to protect my mohair hood so I will go with your recommendation.
David
2020 Roadster 3.7 Dove Grey.
Thanks for sharing Peter...
