7 members (Mark+4, JohnHarris, Alan Patterson, Rastus, bmgermany, RickyH, Hamwich), 169 guests, and 32 robots.
+8Rich 99
Luddite 54
Topics49,905
Posts838,100
#147209 31/07/13 06:47 AM
9 Images
Librand Doorchecks
Here are some snaps of the fitted Librands door checks, as fitted to my 2011 Plus 4.
I find them very useful in keep the door open especially on an incline or when it is windy.
14 Comments
They fit much better than mine.
Georgie - mine are 4 years old now and work the same as on day one! so I think the tubing will be fine. In any event it looks like common plastic tubing which I suspect could be sourced from any hardware store.
Robbie
2021 Plus Four -- Helga
211-WX-1433
Green & Grown Up
Green & Grown Up
Originally Posted By Vancouver
I have just fitted some to my 4/4. Yes, they work well but only when the door is open its widest. If you have restricted space as in my garage, or a close parked car in a car part the do not hold the door open.Jack
It is a good point. All they need is an extra set of 'Dimples' half way along the slot (note to the manufacturer)
I had to give mine a slight squeeze in the vice to make them work on an adverse slope or slight wind.
Maybe I over egged it a bit as the Plastic tube on the drivers side now needs a little lube every so often.
THis was because, on one occasion recently, I opened the door and the tube jammed the unit closed and it ripped the wood screws out of the door!!!!!!! swear
Having had our ankles almost bitten off by both doors, had the Librands door checks fitted.
What a godsend! Agree that the doors have to be fully open for the restraints to work but oh the pleasure of making a controlled exit with decorum, rather than trying to rush out, timing “it” wrong then getting the ankle whacked!
Thoroughly recommended. It’s a shame that the factory doesn’t fit them as standard.
South Wales Correspondent
if you know anyone who has access to the high quality tube they use in heart pumps and similar, then they should be able to blag you some slightly oversize diameter tubing which improves things a lot.
On the other hand, I talked to Rob Wells about this problem a little while ago and he was very happy to sort new tube if the old stuff got pinched ( NOT as in stolen!)
GLLHG
