Posts837,996
Posts: 849 Likes: 2
TM Photographer of 2008 Talk Morgan Regular
Posts: 849 Likes: 2 |
Eek! I've ordered both sides in case they changed it. I don't like the idea of odd brackets, even if only I know!!! The old style ones like yours broke on both sides.
Ken
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
Maybe Suplex need to add an alternative bracket as a replacement to the factory item to their new kits if this is indeed a weak point.
Posts: 167 |
Better metallurgy should solve the problem although it would be more expensive to use a better alloy.
'65 +4 four seater
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
There's not enough shear area (metal) around the holes. Should be at least one hole diameter.
Richard 1976 4/4 4 Seater
Posts: 27,836 Likes: 761
Posts: 27,836 Likes: 761 |
Not good news. Are all cars the same I wonder. Must check mine once back from the sub continent on Sat.
Posts: 1,711 Likes: 1
Posts: 1,711 Likes: 1 |
Dave,
As you have all parts, I assumed it broke but still stayed in place?
Graeme: 2011 +4
Posts: 979 |
[quote=DaveW What is amazing is that we motored over 400 miles with the offside damper totally disconnected. It never banged and there were some periods at fairly high speed round corners, and it never felt twitchy. [/quote] We drove back from LMC last year with a failed rear shock on the Aero, only noticed it a few days later when spotting an oil drip on garage floor. Makes you wonder what they actually do?
Gone to Porsche Part of the Furniture
Posts: 4,333 |
[quote=Hopwood]We drove back from LMC last year with a failed rear shock on the Aero, only noticed it a few days later when spotting an oil drip on garage floor. Makes you wonder what they actually do?  [quote/] Remove all 4 and you will soon find out
Both my rear ones must have fallen off years ago
Posts: 472 |
Dave.. my metalwork (and technical drawing!) teacher would have smacked me over the head (they did in those days) if I made (designed) something like that! It has been redesigned but it can still break I'm having trouble understanding how it can break so cleanly without damage to the damper...
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS -04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
