6 members (Clipper, Image, TalkMorgan, Grumpy2, James B W, RichardV6), 246 guests, and 35 robots.
+8Rich 94
John V6 49
Posts837,993
rockabilly john
Page 2 of 10 1 2 3 4 9 10
U
TM Photographer of 2008
U
Originally Posted By DaveW
Eek!
I've ordered both sides in case they changed it. I don't like the idea of odd brackets, even if only I know!!!
The old style ones like yours broke on both sides.
Ken
Maybe Suplex need to add an alternative bracket as a replacement to the factory item to their new kits if this is indeed a weak point.
Better metallurgy should solve the problem although it would be more expensive to use a better alloy.
'65 +4 four seater
There's not enough shear area (metal) around the holes. Should be at least one hole diameter.
Not good news. Are all cars the same I wonder. Must check mine once back from the sub continent on Sat.
Dave,
As you have all parts, I assumed it broke but still stayed in place?
Graeme: 2011 +4
[quote=DaveW
What is amazing is that we motored over 400 miles with the offside damper totally disconnected. It never banged and there were some periods at fairly high speed round corners, and it never felt twitchy. [/quote]
We drove back from LMC last year with a failed rear shock on the Aero, only noticed it a few days later when spotting an oil drip on garage floor. Makes you wonder what they actually do? smirk2
Gone to Porsche
Gone to Porsche
[quote=Hopwood]We drove back from LMC last year with a failed rear shock on the Aero, only noticed it a few days later when spotting an oil drip on garage floor. Makes you wonder what they actually do? smirk2[quote/]
Remove all 4 and you will soon find out doh
Both my rear ones must have fallen off years ago smile
Originally Posted By uvk33n
Originally Posted By minikeefy
Dave.. my metalwork (and technical drawing!) teacher would have smacked me over the head (they did in those days) if I made (designed) something like that! banghead
It has been redesigned but it can still break
I'm having trouble understanding how it can break so cleanly without damage to the damper... confused2
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
