8 members (GrumpyPa, Morganmike, JohnHarris, Julian BB, Alan Patterson, Mark+4, Clipper, BobtheTrain), 108 guests, and 22 robots.
+8Rich 102
John V6 66
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
Nice hardtop
International Morgan Day
by Deejay - 17/09/26 02:45 PM
2001 +8 Temperature gauge
by AlanB - 16/09/26 07:39 PM
Longest owner?
First Morgan as it is now
by Strathaven, September 15
Topics49,927
Posts838,410
Page 11 of 16 1 2 9 10 11 12 13 15 16
le Asbo du Bling
le Asbo du Bling
I think you'll find that might be the capacity of the bevel box.
Slowly going green
There's a good chance, even a box that doesn't have a breather... actually does, even if it is not obviously a breather. Oil expands and contracts with temperature a bit, and the air contents likewise.
I could visualise a blocked breather causing the bearings to leak.
yes, picture attached, car after 500 miles
Q
Q
u need to degrease down that area asap!i would go crasy,I'm a clean freak
soapbox
don't forget that a M3W is meant for driving too. I am not going to open the boot protection just for the sake of cleaning some parts after every drive. It requires to unscrew/screw 8 hexa screws. Without oil leaking it should however stay cleaner.
Q
Q
Ofcourse when i get my m3w im gonna drive it alot also,its going to be one of the top miles m3w if it doesnt break down.but yes the oil makes it look and be much worse,plus when im going to drive it in kuwait,there wont be water nor mud on the streets.only on cool clear days
HJP Offline
Only 8 screws ? I've got 11 !
Hugh
Not an expert but I understood the oil breather (which comes up under/ behind the air filter) was for engine oil not the bevel box - where you see the "leak"?
I had a leak from one of the push-rod covers which led to oil all over everything below this - engine mountings, number plate etc. My dealer has checked this, emailed pics to the factory and now ordered a new seal. Originally he thought it was coming down from the air filter/ oil breather though, as he said he often sees this.
There is one on the bevel box too, well at least on some of them :-)
Sad to say but I am garaging mine until the rear sprocket can be replaced with the newer version. The noise of it is drowning out the tailpipe burps and one of the guys at the local filling station commented to me about it after I coasted in and it was still noisy!
