2 members (Plus Four Guy, Hamwich), 144 guests, and 15 robots.
+8Rich 102
John V6 66
Old Book
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,932
Posts838,511
Peter1062
Page 5 of 9 1 2 3 4 5 6 7 8 9
Organ pedal is a good mod, is there a throttle cable through the bulkhead or is it fly by wire? 4/4 Sport throttle was cranked so roller was attached from offside of pedal: (note modded bolt )
Originally Posted By Jays
I do hate the shroud. I fitted an Allon White one on my 4/4 which looked nice but was a swine to fit properly due to the leather covering. I've still got the original one from the 4/4 and I might try a bit of surgery and reconstruction on it!
In Morgan's defence, the shroud does work ok with their ugly Mountney standard wheel as the centre boss hides that raw edge. It's our fault for wanting to replace the steering wheel with something nicer!
Jay, if you would like to bring the cover to the Thrill on the Hill event I will undertake to make a mould which I will then modify to create a cover that will fit with the Moto-Lita boss much better. I will post you back the original unharmed. (My original is leather covered so I don't want to work with that)
Nice work on the Half Tonneau ......I made one up for the 4/4 in Everflex when I had the standard 9 stud hood fitted. It was very satisfying making it although piping around the sharp radius corners of it almost wrecked my sewing machine! I'd like to have done the same for my Roadster but the shape is too complex so Allon white will make one for me in January......they are booked up so far ahead!
I assume your roadster has an Easyup hood. If they get something nice worked out I will buy one for sure. I have been thinking of having one made that is combined with the hood cover or fits over the hood cover.
If I can lay my hands on the shroud ( just been looking for it and its not where I thought it was!) you are very welcome to borrow it Peter.
Yes, my Roadster has an Easyup. AW made one for the 4/4 when I had their hood conversion and they made a nice job of it. I may ask them to make up something to my own design for the Roadster....with flaps that come down behind the seats.
DaveW Offline OP
No Nick it's a fastener!
No fly by wire - it's a cable..........
The cowl is horrible, but interestingly the Motolita on Bumble has a much thicker boss than the earlier version. I'm still thinking about how to fix this, it's not insurmountable.
Nigel, definitely no wood on later cars and I reckon it's because the column is an inch lower and fat thighs won't fit between very easy!!!
Now then, Bumble has tested me today. I started on cleaning the underside and couldn't shift the centrelocks!!! I sorted the front nearside with Hulk like violence....... I hate the nearside because being right handed, it's an overhand hit....... Anyway, on the other three, I heated the nut with Mr Blowlamp which made it easier.
The long bolts and Dinitrol arrived today - perfect timing.
I decided to fit the reaction bars, but couldn't restart the first top lube bolt in the thread. It's an unusually fine thread for a big bolt, and I lost an hour this morning farting about with it. I was on the verge of dropping the kingpin, but decided to persevere without the reaction bar for now. I had to file the starter thread in the end but got it back in. Very frustrating.
That will have to wait for winter now!
So on to todays jobs:
Front wheel off and alot of surface rust after just over a year.
This sums up well my view of taking care of things because leaving it like this will just make things worse........
Anyway.............this one shows how the grease can build up on the rebound spring, and needs checking fter greasing.
And here is the raw track rod and end.
If you don't clean the inside of your wheels, you can't be in my gang.
I've had this can of Tectyl 506 for years. I had two for a reason that is lost in time, but I donated the second one to the son in law.
Decided to paint the spinners - spivvy or what?
Just could not resist the temptation..........
My weapons of choice.........
Now licked over with paint, the flash weakens the colour.
Debris from the outer edge of the front wing: Yuk.
Anybody got a budgie?
This is after cleaning and reapplying Tectyl.
Chassis and floorpans. Clean up well don't they!
Some of the seat nuts are just visible as gold blobs.
Mmmmmmmm!
The rear after a bit of effort. Confirmed it's an LSD today.
Final job today was to strip the exhaust.
I don't like to see a dirty exhaust, and it had to come off to get access to the running board on that side.
So for today, that's it 0900 to 1900, so ten hours with a short lunch break, and good progress.
The Dinitrol has allowed me to repair the rear wing erosion. I still have to do the offside half and refit the exhaust, but after that I can start 'enhancing'.
I now have two days at work, so limited time is available until Saturday. Sunday is spoken for, so Monday will probably see the hard and dirty work completed.
I'm having a lot of fun though. Being OCD can be fun.... grin2
Seems John H Sheally also likes yellow Morgans Dave - thought you might like these pics.
2016 Carmine Red 991.2 C4S
Cont
DaveW Offline OP
Very nice Plus 8...............
Great info Dave - thanks.
Drive on the Wild Side
Looking good Dave, if you continue at this pace you will run out of things to do, then it will be another Morgan, and a new garage! innocent
cheers
PS Sue says thanks for recipe. thumbs
Adrian
Formerly known as Aldermog
PS. Did you get your Organ Pedal from Rutters? I've got one on order and they've just run out!!
I called Melvyn yesterday and he said they had stock....we shall see if/when it arrives. Price has just gone up though.
