2 members (Plus Four Guy, Hamwich), 145 guests, and 16 robots.
+8Rich 102
John V6 66
Old Book
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,932
Posts838,511
Peter1062
Drive on the Wild Side
Dave, looking good, where do you get the wire wheel blanks, I might do this and paint to match? cheers
Adrian
Great info as ever Dave. Very enjoyable.
Originally Posted By deano
Dave, the pictures of the under dash fuses, plugs etc: all looks a bit diy?
It's a Morgan!
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
DaveW Offline OP
Scuff and dirt Jay!
It'll be fine - there's an 80A master fuse on the battery, so that will blow before it catches fire (fingers crossed).
Deano - the DIY feel is what makes me feel at home!
Adrian - The Plastic Man:
http://www.theplasticman.co.uk/index.php?area=calculator
Acrylic (Perspex) sheet - 5mm thickness available in "Ivory".
Specify one hole and put dimensions in the narrative.
For the Roadster it was 360mm with a 160mm hole, but double check. Get it right and it fits perfectly, holding in place with two small neoprene pads. It arrives with protective film on both sides, so you can chose to keep one side protected, although I strip both sides. A fantastic piece of plastic. Laser cut, with polished edges, and as clean as a whistle.
Thanks thumbs
Adrian
DaveW Offline OP
Off to stay with the Piskies until Thursday. Back on line then. goodnight
DaveW Offline OP
Post Photobucket Re-boot from October 2013.
After a pleasant family Saturday with my daughter in Derby, I awoke Sunday morning with full blown General Malaise - level 4.
Aching bones, dry mouth, headache, runny eyes, runny nose, you get the picture, and it was not all alcohol induced either. So after beating a retreat home, I've spent Sunday, Monday and Tuesday being tended to, either on the sofa or in bed. It wasn't until this morning that I could face up to the garage.
My first job was to replace the revcounter. The planned switch didn't work at Shelsley so it's been done remotely.
The following photo shows the instrument, which is designed to fit 'many' cars, and is tuned by selecting the appropriate micro switches. You'll see that the original has 8 switches but the replacement only has four, thus ruling out a like for like swop. Anyway it's fitted and so far is working fine. There is one other thing to note, the instrument is held bu a U shaped metal bracket and two knurled and threaded nuts. The bracket is slightly oversize and works far better with a half inch or less hacksawed off each end. Original to the left:
To gain access, drop the steering column to its low point, remove three crosshead screws between the column and the A post and you can slide your hand up and under.
There are 'several' spare wires and plugs cable tied to the securing bracket.
This is the view under the dash in that corner looking straight up. The red & black wires are to the panel rheostat. The roll hoop is very evident. Lots of electricity in this corner. You can see the feeds to the main fuse box on the bulkhead.
Looking along the dash towards the nearside. The other instruments are visible, as is the wiper rack housing at the top. Surprisingly dusty but I suspect that some of this will be MMC dust.
This is looking up and right towards the A post. There is a main 12v feed post junction (same on my Roadster) and a seperate junction box which can be fixed to a panel, but not in this application. The main fuse box is just the other side of here, on the bulkhead under the bonnet.
While I was under there I tightened the two fasteners for the screen frame - different sizes, then did the other side.
Under the passenger side, and what surprised me was that the glove box has a metal base - might even be stainless steel.
This is looking towards the offside, and there are plenty of spare connectors. Also visible is the 12v power socket, and the diagnostic plug.
The problem - is that plug, when fitted properly is too close to the top of the handbrake. So I've pushed it in slightly without losing it into the dash. Note also that 'MMC?' has used 3mm standard density self adhesive neoprene to cover the metal brackets which hold the dash base in place. They are now covered in leather, Ha!
Those fuses under the dash are smaller than standard bayonet - research is needed.
More to follow...........
DaveW Offline OP
So my next job was............
When I bought one of these for the Roadster, the red was a perfect match. This time not quite so lucky, the yellow is more of a number plate yellow.
So, here's the spare:
And now......
Because it doesn't quite match I'm wondering if I should have gone for black. Anyway I can always get one and compare.
The dimensions for the 4/4 wheel are diameter of circle 322mm, diameter of hole 165mm. Available from 'The Plastic Man', where I also get my windstop acrylic.
And at that point I stopped for today, but next job is the steering column cowl, so watch this space.
SBM Offline
One option if you can't colour match the circle filler piece is to cover in a bright fluorescent reflective on one side and some of the 3M black reflective on the other. This shines white in headlights.
That way you can have it in many guises, to suit the journey and conditions.
