8 members (sid, DavidR, Alan Patterson, MATTMOG, Bunny, Bilymog, linklaw, Strathaven), 315 guests, and 25 robots.
+8Rich 99
John V6 55
Topics49,906
Posts838,104
Hook Offline OP
Chaps, any ideas on this subject please? On my 'new' car I have quite a few windscreen scratches and have been considering buffing with jewellers' rouge but I have read 'somewhere on google' that this RainX stuff does a good job of filling scratches. I'm not keen on vandals resolving the matter with a brick!
Any wise words welcome.
Cheers, Dave
Dave
Dave
I had a scratch on the inside of my new plus 8 screen. It was replaced by the factory under warranty.
Martin (Deano)
I have used some jewellers' rouge where I had used a nylon pot scrubber to get a splash of some sort of resin (sprayed off a passing truck) off my Alfa's windscreen. Unfortunately it was a new pot scrubber and more abrasive than I would have imagined. I won't do that again frown
It did a reasonable job but the scratches were fairly deep and there are still faintly visible marks.
I don't think you will do any harm. I used a new polishing buff and a battery driven drill. I have been thinking of having another go with the power drill. The buff did not leave any visible swirls. If the scratches are fairly light and somewhat localised it is probably worth trying. Be careful about getting a small section too hot. I was worried this may lead to cracking the glass.
Some of the professional glass people offer this service so it may be worth asking around.
Hook Offline OP
Peter, sounds very similar. Interestingly the 'professional' people did offer to do 'light scratches' for more than my glass insurance excess. They suggested I would be better off if 'someone' threw a brick at it because I have some deeper ones too! All repairs can cause 'lensing' which is distracting but insurance companies prefer that to replacement by all accounts.
Trying to avoid replacement and may have a go at DIY then.
Cheers, Dave
Dave
Cheers, Dave
Dave
I have used Autoglym Glass Polish with some success on my 4/4.
Needs a bit of "elbow grease" but even by hand it gave a noticeable improvement.
Bud
4/4 "Stanley"
Glass polish is available from restoration specialists.(try Frosts). It comes as a reddish powder which is mixed with water and applied as a paste with a drill mounted hard buffer. It's made in part with diamond granules as far as I know. It works but takes ages, gets very hot, and spits the cutting paste everywhere so paintwork needs masking. I used it on my MGB and it was a reasonable result, but thats all.
Rain X do a glass polish - a white cream, but I doubt it will shift any scratches that you can feel.
Rain X water repellant won't do much in my experience.
I've used RainX Xtreme Clean on my M3W flyscreens, works well, removes light scratches. My dealer says works well on glass also. If you have really deep scratches, you will probably need something more industrial.
thumbs cheers
2013 M3W # 793
'Mosquito'
Hook Offline OP
Thanks for all your comments, all worth investigating. Autoglym Glass Polish first then I suspect your red powder Dave is jewellers rouge and yes I expect it will get everywhere!
I see Bumble is getting the 'Dave Treatment'. enjoy!
Dave
Yes indeed Dave. Fairy dust I call it. thumbs
Just to clarify my comment on Rain X liquid water repellant - that is excellent at dispersing water. Highly recommended.
Gone to Porsche
Gone to Porsche
Do not use nylon scratch pads on Glass, but fine Steel Wool to remove any substances like paint overspray or the likes.
Do not use the wire wool on plastic, as for the Rain X and others your not removing the scratch your temporarily filling the scratch.
Rouge will work but in a minor way only, polishing out buff marks that wouldn't really effect your vision anyway, then a finishing Glass polish (autoglym).
For best results use the Brick method as suggested.
