1 members (MartO),
125
Old Book
Goodwood
Topics49,932
Posts838,511
Posts: 1,522 Likes: 61
Posts: 1,522 Likes: 61 |
That is strange. According to Mulfab the change in the early 2000s introduced the problem. I can only think that later modifications made by Morgan in 2006/7 resolved the issue. I certainly haven't noticed anything I would call bump steer. Before I fitted the Suplex kit I did occasionally get the front end skipping sideways in hard cornering but now it sticks like glue to the road. My 4/4 is of 2008 vintage but I am not sure the issue was resolved. The separate track rods leading from the steering rack onto the steering arm of the stub axles are canted upwards at an angle of just 1.25deg. By some cosine trig I reckon that the levelling of the track rods (each horizontal on the rebound) leads to a tendency towards a greater toe out of just 0.2 mm. On compression of the suspension however the angle of 1.25 increases and the tendency then is for toe in to be increased by about 1mm at the most (for the brief time the compression maintains). I am unsure if this sheds much light on the issue of bump steer. One or two of our local Devonshire dual carriageways have a trammelled depression into the road surface which does cause the 4/4 to wander alarmingly.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Are the "tram lines" linked to the bump steer? Surely this is the car just trying to fit in the groves left by the (heavier) wider tracked lorries (and cars)?
Richard 1976 4/4 4 Seater
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
There are "tramlines" in a road I use and even my Focus is affected. I feel some "pull" when in them. The Morgan is no better/worse though. The "grooves" in the road have resulted from poor quality "resurfacing" using the quick-fix tar/chippings method that also leaves loose chippings to cause problems with loss of grip/raised banks of chippings etc. The condition or roads is detriorating, I wonder if more money needs to be spent on them  Could the £billions be diverted from HS2? OOPS! taking us off thread - sorry
I believe the track lines are wider due to the wider track of HGVs and you could be right - the Mog likes to try to follow them - but my Volvo estate and daughters Toyota Yaris are not troubled the same way on this stretch of road.
 Devonshire roads are deteriorating for sure. The bit I am referring to is the A38 Exeter/PLymouth section where it passes close to Chudleigh. There have been one or two accidents where vehicles have left the road here and some short sections of it have been re-surfaced but not all .. The Plymouth bound side is worst.
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
My 2009 Roadster with Suplex and brake reaction bars steers and corners almost like a normal car, but in some ways better in that lacking the dulling influence of power steering there is much feel and just enough feedback.
Our modern cars have excellent steering, but both lack much in the way of feedback and the feel is artificial. The BMW, without power, is impossible to steer at all.
Posts: 168 |
..........My 4/4 is of 2008 vintage but I am not sure the issue was resolved. The separate track rods leading from the steering rack onto the steering arm of the stub axles are canted upwards at an angle of just 1.25deg. By some cosine trig I reckon that the levelling of the track rods (each horizontal on the rebound) leads to a tendency towards a greater toe out of just 0.2 mm. On compression of the suspension however the angle of 1.25 increases and the tendency then is for toe in to be increased by about 1mm at the most (for the brief time the compression maintains). I am unsure if this sheds much light on the issue of bump steer. ..... Remember, on bump and rebound the axle end does not go up and down vertically, but slides on the king pin, which is inclined at 2 degrees. Therefore to minimise bump-steer, you would expect the track rod end to be tilted up at 2 deg, so that its arc of travel is tangential to the king pin at somewhere between static height and mid-travel. So I suspect that your 1.25 deg is not far off the optimal position.
Fjemog
1993 Plus 8
 P.S. Have driven the 4/4 in Spain, Portugal and France without coming across any of these trammeled motorways. However on return journey home last year heading up the A38 from Plymouth one of the first things I noticed was this awful section of carriage way as it heads up towards Exeter.
Posts: 14,751 Likes: 158
Posts: 14,751 Likes: 158 |
You think that's bad. You should try crossing from Switzerland into Italy. Then you really do notice a difference. The Autostrada is not too bad but the provincial roads are a disaster.
Posts: 4,896 |
Talk with Darren at New Elms, I had a slight shimmy and buy adjusting the rack and setting it so track rods parallel no shimmy or bump steer.
Adrian
