13 members (TomS, DMC1904, JD44, +8Rich, Grumpy2, MDS61, MJF, The Flitting, asterix, BLUE+4, mph, John07, Graham, G4FUJ),
301
45
Topics48,364
Posts813,336
Members9,215
Posts: 69 |
Still Leaking !!!!! John G4TKO
Posts: 26,759 Likes: 424
Posts: 26,759 Likes: 424 |
I washed my +4 on Saturday ahead of being somewhat beaten at beer (as I was driving & not drinking) & skittles by the Marcos owners club.
As always if the car faces up hill on the drive water "appears" on the tunnel under the radio.
If I point her downhill it doesn't. So for me it is the heater "overflowing". Perhaps that is your answer?
Still the weather was kind for the drive top down there & back unlike today where I got well stung by hail driving over the Chilterns.
Posts: 28,428 Likes: 180
Posts: 28,428 Likes: 180 |
Ahhh, good.
No, not the leak - another amateur radio op.
Hope you get it sorted John.
73 Graham
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
Posts: 69 |
Mark Any progress with the leak ???
John G4TKO
Posts: 7,823 Likes: 81
Posts: 7,823 Likes: 81 |
If Mark, or yourself are still experiencing this, I'm happy to ask the factory on your behalf - I'm sure they will have a solution.
TM Photographer of 2011 Talk Morgan Regular
Posts: 963 |
Yes Simon, please do so. My 2007 Roadster has the same problem, and probably there are more of them out there. Thank you. Salut from Lëtzebuerg, Ivo
 1998 +8 (permanently out of service  )
Will do
Posts: 1,907 Likes: 135
The TM in Talk Morgan Talk Morgan Enthusiast
Posts: 1,907 Likes: 135 |
Okay chaps, I've just had a good chat with Steve at the factory and as always he has been very helpful. He said he believes it will be one of two things: - 1) The seal around the wiper wheel box spindles - basically where the wiper spindles poke through the body is a very tight fit. Morgan fit a seal and then waxoyl around the seal. It is worth checking whether these points are still sealed and if not, applying some waxoyl as if they have dried out, water could seap through. 2) The heater drain hose has come loose - if you lay across the seats and look toward the gearbox cover, there should be a small pipe that goes from the back of the heater through the bulkhead (by the gear box cover). The pipe should be attached to the back of the heater (the heater has a 'stub' pipe on the back of it), this allows again moisture to drain. This can come loose and could cause some water ingress; however, it was stressed that this would generally be the cause of water on the carpet, not the transmission tunnel. I hope this helps  (and again, a big thank you to Steve at MMC) Simon
Posts: 963 |
Thanks for the info, Simon
Posts: 55 |
Thanks Simon,
I'll take a look at these and see if one of them fixes the problem.
Mark
