Posts837,996
Posts: 2,321 |
If all else fails,I'd pop open the bonnets, and get someone to use the hose pipe with running water(not high pressure), directing water around windscreen/bulkhead area, while you look under the dash for actual leaks!!!
ps try keep water away from electrics of course...
Posts: 2,321 |
...use the hose pipe on either passenger or drivers side first, run the water for 5-10 minuntes and wait for another 10-15 minutes for any telltale signs of water sippage..hopefully this should narrow down the problem area
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
John; My 4/4 leaked there and it was traced to the washer tube top where it meets the washer.It was cured with a drop of bostik around the screws. I have another solution on my plus4 to prevent the ingress of water through the top louvres - two under bonnet shields. Meabh.
Posts: 3,826 Likes: 69
Posts: 3,826 Likes: 69 |
Hi, I had water coming in around the wiper mountings and dripping on the tunnel. Sealant around the wipers cured it Nick
TM Photographer of 2011 Talk Morgan Regular
Posts: 963 |
Another point from my to-do list before warranty expiration was water infiltrations. My dealer fixed five places, where water found it's way into the cabin. Great job
 1998 +8 (permanently out of service  )
Posts: 155 |
I've only had my '99 +4 for a few weeks, and one of the things that I've managed to get sorted is the water leak when it gets washed! I applied some adhesive insulating tape over the foam strip that's fitted between the heater box and the bulkhead, which is a bit fiddly without taking the bonnet off, but it seems to have cured the problem. I intend to make a 'proper' job of it later when I can take the bonnet off and apply a strip of black Duck Tape (in one complete length)and trim it so that it looks OK. I hope this helps. Sid
Sid
Ex 2014 3.7 Roadster in Ferrari Le Mans Blue Ex Indigo Blue '99 +4 Ex MogMMX Innovations winner
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
I'm sure Dave W. could give you the correct dimensions and type requirements for neoprene to replace the foam...  Cheers,
Posts: 55 |
Hi All,
The wipers were tightened up by my dealer to solve the water dropping onto the transmission tunnel, it seems to have done the job for me.
Cheers Mark
Posts: 3,439 Likes: 7
Goodwood Drifter Talk Morgan Addict
Posts: 3,439 Likes: 7 |
My dealer fixed five places, where water found it's way into the cabin. Great job if all gets fixed, has it still the charm of an UK-made-car????
Steven sold: M3W, Aeromax,V6, 4/4 4seater now: +fourLM62
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
I have had drips onto my 4/4 trans tunnel too. I have taped the grommet that cables use to go through the firewall and am waiting to see if that was the source. gaffer tape test before final solution. I don't think its the washer jets - the grommet is in a likely spot though as its position seems to be about right.I could look uder the dash while a hose is used as "rain" though.
