1 members (Saxonian),
333
Topics49,904
Posts838,088
Posts: 213 |
How many quarts in a 3 wheeler?
2005 Roadster 2013 M3W MOG South
Posts: 414 Likes: 6
Posts: 414 Likes: 6 |
6 Liters - so just over 6 quarts...
I bought the Mobil 1 VTwin 20w50 oil.
Going to do my oil and filter change this weekend...any tips?
1965 Plus 4 2008 997 Turbo Cab 1981 Alfa Spider 1954 Austin Healey 100 (SOLD) 2013 M3W (SOLD)
Posts: 1,562 |
Crowbar - please take some pics as you do your service , will be much appreciated  You are blazing a trail here
Posts: 1,947 |
Crowbar
Dealer takes off the oil pipes on RH of engine, mark them first, he did not use drain on header. I took off the transission tunnel cover & noticed a grease nipple on rear CV joint. So probably on front & sliding sleeve as well. I think there is a plate to remove for access from below.
Tim.
Posts: 1,461 |
Going to do my oil and filter change this weekend...any tips? 5.28 quarts for those who do not reside in our former colony.
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
I called in at Millers Oils in Brighouse today to see what they have for the 3 wheeler. Their Classic 20-50 will do the engine and they also do an EP140 gear oil which is the correct grade for the BB. I ordered some EP140 as it is not a stock item and has to be made up specially. There's not much call for gear oil you can stand a spoon up in.
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Motul V300 20/60 And motul gear 300 70/140 for bevelbox
