0 members (), 323 guests, and 40 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,088
How many quarts in a 3 wheeler?
2005 Roadster
2013 M3W
MOG South
6 Liters - so just over 6 quarts...
I bought the Mobil 1 VTwin 20w50 oil.
Going to do my oil and filter change this weekend...any tips?
1965 Plus 4
2008 997 Turbo Cab
1981 Alfa Spider
1954 Austin Healey 100 (SOLD)
2013 M3W (SOLD)
Crowbar - please take some pics as you do your service , will be much appreciated thumbs You are blazing a trail here notworthy
Crowbar
Dealer takes off the oil pipes on RH of engine, mark them first, he did not use drain on header. I took off the transission tunnel cover & noticed a grease nipple on rear CV joint. So probably on front & sliding sleeve as well. I think there is a plate to remove for access from below.
Tim.
5.28 quarts for those who do not reside in our former colony.
I called in at Millers Oils in Brighouse today to see what they have for the 3 wheeler.
Their Classic 20-50 will do the engine and they also do an EP140 gear oil which is the correct grade for the BB.
I ordered some EP140 as it is not a stock item and has to be made up specially.
There's not much call for gear oil you can stand a spoon up in.
Motul V300 20/60
And motul gear 300 70/140 for bevelbox
