1 members (New Zealand), 129 guests, and 16 robots.
+8Rich 103
John V6 66
Old Book
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,932
Posts838,511
AlexCreasey
Page 3 of 6 1 2 3 4 5 6
DaveW #175448 11/01/14 06:33 AM
Bob, the only other downside I should have mentioned...well two really, they are expensive and they do wear faster. I was recommended Vredestein Sprint Classic as a good alternative.
DaveW #175466 11/01/14 08:52 AM
I have Vredestein T-Trac in the original size.
Softer sidewalls than the Contis (van tyres) so a little softer on the ride without compromising the handling.
DaveW #175798 12/01/14 08:40 PM
Firestone F560s are good in wet and dry, and in my view better than the OE Contis.
DaveW #175802 12/01/14 09:08 PM
Rog Offline
Out for a drive in the sun yesterday and as I was coming up to a tee junction an elderly gent kangarooed out and stop dead in front of me. The Mog pulled up on a sixpence just feet from his door. Smiled at the very sheepish looking chap and then said to swmbo “ I wonder where we would be now if I hadn’t changed those tyres”
Vredesteins! notworthy
Roger
Dave the standard tyre size unless they have change it is 195/60HR15. The thing is that Morgan adjusts the width of the mudguards depending on what tyre width is ordered. The 195 is 10mm wider than the 185 fitted to the 4/4 2 Litre so will probably stick out a fraction, perhaps only a few mm, and be more likely to throw road grime, mud etc. outside the guards.
If you are worried about ground clearance you need to be careful too. A good site that allows you to do tyre comparisons is http://www.1010tires.com/Tools/Tire-Size-Calculator
but they no longer list the 185/70HR15. Attached is a pdf file of some information I obtained regarding changing my tyres to 195/65HR15.
Hi Peter, I only noticed this thread now and am very interested in your attached PDF file.
My car (+4, 2010) came from the factory with 195/60HR15 Yokohama tyres and I got to say I find them to be great, both in dry and in wet conditions. No complaints, I even did my first few hillclimbs with them and they did the job as needed.
(now I swap tyres when racing, never looked back after the first time I mounted 4 TOYO Tyres that totally transform the car. These are very low 195-50-15 tyres, but mindblowingly grippy)
With the Yokohamas, as I said, no complaints, except ... ground clearance. Even with all the care in the world, getting the car safely in and out of steeped ramps into/from underground parkings is very tricky.
I noticed you fitted tyres with the same width and slightly higher sides (65 instead of 60). From the PDF table you attached that ups ground clearance about one cm. Does it make a "real" difference? And doesn't fifth gear get too long, therefore hardly usable?
Thanks in advance, soon I'll need to buy new road tyres and will have to decide if I keep the current specs or go for something different.
2010 Morgan +4
2014 M3W Brooklands
To be raced
DaveW #176094 13/01/14 10:12 PM
I have not yet fitted them but I recall that a Swiss owner has and a couple of other people. It will make a small difference in the ratio and I may have to adjust the speedo. The Plus 4 has no problem pulling 5th gear and a slightly higher ratio for touring would be fine. Also I intend to fit a throttle body kit that will lift the output to about 180hp so that should cover it. The link to the tyre size calculator will give the table that I have in the file, it was the source of my figures, but will also give the change in speedo reading as a percentage.
I too have only just enough to clear the ramp to my garage and if the tyres are down a bit I do touch despite the fact that the rear springs were changed to 5 leaf springs under warranty just for this problem. I will eventually change the rear springs to the Suplex kit that is under development and I will probably change the tyres at that point.
DaveW #176097 13/01/14 10:18 PM
oi? What's a "throttle body kit" ??? I want!
2010 Morgan +4
2014 M3W Brooklands
To be raced
http://www.omextechnology.co.uk/
Local to me. Worth a look. Was chatting to them at the Autosport show last weekend.
DaveW #176142 14/01/14 07:33 AM
I'm just waiting for them to come back to me with final prices for my kit.
Same tyres as MarioCP here. 195/60 15 Yokohama C-Drive factory-fitted.
They are great tyres in the dry, but I disagree with Mario in the wet. They are ok in the wet, but in a safety training we did comparisons in the wet, stopping, circle and the "elk test". Someone with a 4/4 and narrower tyres (looked like 155 all year tyres) was much better off, the Yokohamas were average, and a chap with Continental Sport Contact tyres did struggled with extremely long stopping distances, all in the wet.
But driving in the wet is not my main preference, so I stick with the Yokohamas, because on dry and especially warm roads they are very good and reasonably comfortable.
btw: tyre pressure matters. I run them at 1.7 bar cold, front and rear.
Andreas
+4
