3 members (+8Rich, SailingTom2, RichardV6), 357 guests, and 21 robots.
+8Rich 101
John V6 64
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,216
MossyfromNZ
Page 6 of 1,342 1 2 4 5 6 7 8 1341 1342
I used some silicon sealant to hold them in place...worked well and easier than glue to use (in my opinion).
Hamwich - first try line of sight. I use a pencil type torch in the teeth (Commando style but end on), but a head light might work.
If you can get a hand up, all well and good. If not, first check the diameter of your new pipes. It might be worth inserting a narrower bore pipe up inside the original as a guide, then pull off the original, and slide the new pipe over the guide pipe. I would secure with a band of double sided tape, my best friend. If there's any slackness in the fitting, you'll need to pad it out. If you need a sample of neoprene or leather,(enough to pad) give me a shout.
Drove plenty of Morgans today, like most days smile
- Lawrie Mills(Chunkylozza)
Youtube - ChunkyLozza
Drove it four inch in garage to prevent tyre flat spot and charge battery on account of it p******g it down as usual gloomy
2016 Carmine Red 991.2 C4S
Same here, except I wheel the 4/4 back and forward inside the garage.
gloomy umbrella
Bud
4/4 "Stanley"
I just sat in it and started it up....just so I could hear my new silencers. How sad is that!
I drove mine to Dublin today in the pi**ing rain following lorries which covered it in dirty spray----- major wash tomorrow!!!!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Took ours out on the Melbourne to Mornington classic car run, about 10 Morgans showed up and it was fun going down as a convoy Still hankering after an E type,there were some great ones on display
Jeff
Pink 4/4 2011
WR142LL Offline OP
The harder the rain, the quicker the salt gets washed off !
Jeremy
2009 4/4 Sport Green
And nothing else !
I can just watch, to cold to even start the engine... snow
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
