Topics49,880
Posts837,772
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
I used some silicon sealant to hold them in place...worked well and easier than glue to use (in my opinion).
Richard 1976 4/4 4 Seater
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
Hamwich - first try line of sight. I use a pencil type torch in the teeth (Commando style but end on), but a head light might work. If you can get a hand up, all well and good. If not, first check the diameter of your new pipes. It might be worth inserting a narrower bore pipe up inside the original as a guide, then pull off the original, and slide the new pipe over the guide pipe. I would secure with a band of double sided tape, my best friend. If there's any slackness in the fitting, you'll need to pad it out. If you need a sample of neoprene or leather,(enough to pad) give me a shout.
Posts: 2,361 |
Drove plenty of Morgans today, like most days
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 4,654 Likes: 124
Posts: 4,654 Likes: 124 |
Drove it four inch in garage to prevent tyre flat spot and charge battery on account of it p******g it down as usual
2021 Lapis Blue Plus 6  You know it makes sense!  2016 Carmine Red 991.2 C4S
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Drove it four inch in garage to prevent tyre flat spot and charge battery on account of it p******g it down as usual Same here, except I wheel the 4/4 back and forward inside the garage.
Bud 4/4 "Stanley"
Posts: 14,009 |
I just sat in it and started it up....just so I could hear my new silencers. How sad is that!
Posts: 3,480 Likes: 42
Posts: 3,480 Likes: 42 |
I drove mine to Dublin today in the pi**ing rain following lorries which covered it in dirty spray----- major wash tomorrow!!!!
Posts: 152 |
Took ours out on the Melbourne to Mornington classic car run, about 10 Morgans showed up and it was fun going down as a convoy Still hankering after an E type,there were some great ones on display
Jeff
Pink 4/4 2011
Posts: 1,418 |
The harder the rain, the quicker the salt gets washed off !
Jeremy
2009 4/4 Sport Green
And nothing else !
Posts: 472 |
I just sat in it and started it up....just so I could hear my new silencers. How sad is that! I can just watch, to cold to even start the engine...
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS -04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
