Morgan Aero 8
9 members (sewin, Jon G4LJW, linklaw, nick w, MATTMOG, Mogdavid, High Hamster, Grumpy2, bmgermany), 192 guests, and 37 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,041
#181988 14/02/14 03:22 PM
Well I've had my Supersports since November, using her most days for work and pleasure, and absolutely love it. I have never had the pleasure of driving something so individual and alive.
However, I am starting to get really upset with the wet lap I get whenever I drive her in the rain! The water appears to drip off the windscreen trim, down and onto my lap. I can also see the water pouring down the inside of the screen, and behind the dash. Anyone have any recommendations or should I just remove the screen and re seal it? Is this something Auto windscreens can do??
I have also just changed my head unit for a Kramer single din navigation unit, and the aerial wire had corroded and was wet too! I am thinking I need to pay more attention to the weather man when I plan on taking her out!
dmh Offline
Have faith Artichoke.
I think most of us have experience of "leaky MOG's" - but it does seem to get sorted by a good dealer.
I don't think a leak test is undertaken at the Factory - usually has to be fixed later.
Good Luck
David H
dmh #181991 14/02/14 03:46 PM
Thanks David. Hey, its not an issue and all part of the honour of owning something so special I suppose. I will man up, and maybe stop off at the factory when Im next passing.
Artichoke.
For most of us (though I can't speak for Aero owners) it is a case of minimising the leaks, rather than getting rid of them.
I would have hoped that an Aero Supersport (my dream Mog) would be "drier" than a Trad and would therefore hope that a bit of fettling by your dealer or the factory would improve the situation.
On a Trad, the black art of minimising leaks almost warrants an entire website of its own; but ultimately, most of the Mog owners that I know carry a towel in the car!
Good luck
Bud
4/4 "Stanley"
My 4/4 is almost watertight roofwise.
But water enters through the floor, so I always remove the carpets after driving in the wet.
The glove compartment is another wet area, but I suspect this has been cured after I replaced the gaskets around the windshield wiper exit.
But when using the window washer fluid with roof up, the wind will squeeze it into the corners where it will end up on the occupants in my Mog.
So I use non alcohol washer fluid.
4/4 2 seater 2001 model
Formerly known as Aldermog
Originally Posted By Budster
Artichoke.
.... most of the Mog owners that I know carry a towel in the car!
Good luck
And a microfibre cloth to wipe condensation off the side windows!!
Worryingly Aldermog is, other than the small gap at the lower front of the side screen, waterproof driving into rain: a truck going past on a very wet road is a bigger challenge... Another reason to avoid Motorways!
If it's a supersport targa then there were different rubbers that were available AFAIK... you may want to call the factory.
Towels must match the car colour obviously. Either paint colour or interior colour, and top quality. grin2
My +4 is has no Leak's apart from driving roof down in the rain
Very much in the dog house, could be up for rehoming
Dave you forgot to add "and made of neoprene!"
