5 members (Gramrugby, moggin, TBM, sewin, Alan Patterson), 205 guests, and 57 robots.
+8Rich 63
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,769
Page 13 of 1,342 1 2 11 12 13 14 15 1341 1342
When I come down tomorrow please can you hide that Lotus......I do not want any temptation! Easter would never forgive me!
I still think we should have a driving session at Lotus, to taste the Elise and Evora... smile
crazy2 laugh2 woohoo drive
Yes, Yes, Yes
Finally shoulder felt good enough to drive. I dont care if it was on the freeway in early peak hour, i did it.
A little tender by the time I arrived at work, after all it was 26Km and that is at least 260 gear changes laugh2. Never mind it will get better in time for me to drive home. I will probably cop an earful from swmbo but it will have been worth it drive
Graeme: 2011 +4
Brilliant news Graeme - no stopping you now woohoo thumbs
One Hopes,
I can now drive it to get the motor changed over. spend
Graeme: 2011 +4
Yes, Yes, Yes
Great to hear!
WR142LL Offline OP
Ross on Wye was lovely yesterday in the sunshine but D-hell the amount of water !
However, have wimped out today as am going to the Theatre at Malvern love tonight and the forecast is unrelenting gloomy
Using swmbo 's camper van instead : advantage = ability to make a brew if held up anywhere coffee
Jeremy
On a cold and blistery day here in Florida, but sufficient for Morgan jaunts, I finally found the rear end clank that plagued my runs in the Plus 8 of late. The tubular shock tower is both bolted and welded (belt and suspenders?) to the angle iron cross member that sits at the top of the shock hoop. The passenger side weld was broken and the bolt loose. I tightened the bolt to within an inch of its life. I suspect the weld should be re done. Any similar experiences or thoughts?
Cheers,
Mark
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
Wet and windy drive down the M5 to Williams today. The trip tested my new windscreen pillar trims out....no more popping out of the side screens! Just need to get the single drip from the header rail sorted!
My wallet stayed firmly in my pocket even if my taxi drivers didn't (you know who you are!) and in spite of seeing and hearing the rather impressive audio set up Williams have just fitted to a customers Roadster. Nice to see a fellow TMers car there also being fitted with something similar.
......it was only a dash clock, nothing too expensive, this time.
The audio system sounded great.
Nice friendly dealership.
Ian
