Topics49,920
Posts838,283
Posts: 2,361 |
Good to see you both today.
I'm sure I can do the same stereo to your Morgans as I did to the green roadster that you saw.
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 14,009 |
Ha ha.....I'm sure you could! I may be tempted after I've had the other planned improvements done! It was impressive and that comes from someone who's home audio system is Spotify and my Mac!
Posts: 2,361 |
Ha ha.....I'm sure you could! I may be tempted after I've had the other planned improvements done! It was impressive and that comes from someone who's home audio system is Spotify and my Mac! Let's get your planned improvements done and then go from there. I did manage to Mog drives today. The 4 seater was alittle lairy in this wind lol
Posts: 14,751 Likes: 158
Posts: 14,751 Likes: 158 |
Just need to get the single drip from the header rail sorted! John. Morgan have a thicker seal that can be fitted into the base of the header rail chanel that should solve that problem.
Posts: 3,643 |
I'm sure I can do the same stereo to your Morgans as I did to the green roadster that you saw. Good to see you too. The stereo installations is very discreet and sounds tremendous.
Posts: 2,361 |
I'm sure I can do the same stereo to your Morgans as I did to the green roadster that you saw. Good to see you too. The stereo installations is very discreet and sounds tremendous. Thank you, it took a little while to install neatly but your correct it does sound superb. We finished the 4 seater tonight as well and that sounded amazing for what his budget allowed. Plus he also had a remap
Posts: 14,009 |
Just need to get the single drip from the header rail sorted! John. Morgan have a thicker seal that can be fitted into the base of the header rail chanel that should solve that problem. I've already got that seal fitted Peter. I think the water might be travelling along from that gap at the top of the screen supports so the next step is to fit a pair of neoprene pads a la Dave W.
I can recommend that. The only other thing that worries me is the water that accumulates in the side screen window chanels. I think I can resolve it by drilling a drain hole but I am not sure just where to drill it.
Posts: 3,643 |
I can recommend that. The only other thing that worries me is the water that accumulates in the side screen window chanels. I think I can resolve it by drilling a drain hole but I am not sure just where to drill it. I am with you on that Peter, I hope someone on the forum has a neat solution to that issue.
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
I can recommend that. The only other thing that worries me is the water that accumulates in the side screen window chanels. I think I can resolve it by drilling a drain hole but I am not sure just where to drill it. +2! When you know please post, I have the same problem and when the passenger door is opened all the water runs back along to soak the passengers legs. It isn't appreciated!
