2 members (+8Rich, TeddyAds), 218 guests, and 29 robots.
+8Rich 95
John V6 52
Posts838,002
rockabilly john
#195845 03/05/14 03:18 PM
TonyR Offline OP
The fuel gauge has stopped working on our 57' +4.
There is 12 volts going in to the gauge and a tad over 5 volts coming out to the sender unit.
Is the gauge faulty?
TonyR #195866 03/05/14 03:44 PM
Voltage regulator??
TonyR #195870 03/05/14 03:54 PM
TonyR Offline OP
There isn't a voltage regulator in the circuit.
TonyR #195874 03/05/14 04:09 PM
If you ground the signal wire that goes onto the sender unit the gauge should read max with the ignition on, if it does and you can get it out remove the sender unit and (a) check float has not dropped off or is full of fuel (b) check by earthing it and moving over the range and see if gauge moves. After that an Ohms meter and check the signal wire is not open circuit. If all the checks are OK all that's left is a faulty gauge I am afraid.
BR Colin
