2 members (Carbuilder, DavidR),
367
Topics49,897
Posts838,017
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
I've just pinged Simon regarding a couple of new 'sticky' thread headings for the Three Wheeler section & wondered what the heat on the street was about what you'd like to see regularly?
My suggestion would be something like 'Popular Modifications' as a starter for ten, but what would you like to see..?
Posts: 1,947 |
'Check it now' for potentially dangerous faults like the one with loose fuel hoses spraying fuel on the engine
Tim.
Posts: 7,934 Likes: 133
Posts: 7,934 Likes: 133 |
Two suggestions: - Have a register thread - this was supposed to be it but it never got off the ground. Why not start it fresh and I will make it sticky in here. Have a Modifications thread
Posts: 698 Likes: 7
Toys for Boys Talk Morgan Regular
Posts: 698 Likes: 7 |
The things I would like to see are..
Morgan upgrades - comfort kit, bevel box, etc
After market upgrades - Suplex, Empire Racing, Fairboure screens, etc
DIY upgrades - mudguards, oil temp gauges, dashboard improvements, etc
Check it Now - spraying fuel, disintegrating belts, cracked chassis, falling off exhausts, cracked bobbins, etc etc etc etc etc etc etc etc etc
Omne trium perfectum
Posts: 1,299 |
 2013 M3W # 793 'Mosquito'
Posts: 1,653 |
Posts: 2,094 Likes: 260
The TM in Talk Morgan Talk Morgan Expert
Posts: 2,094 Likes: 260 |
You can add your car to the M3W registry here .
Posts: 1,642 |
About the registry (can't wait to post there  ) I remember reaing that the cars have more than one number (frame is not equal to chassis and I think there's even a 3rd number somewhere). So ... what is the valid number for registry purposes?
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
Can I suggest that the end of the long VIN number is the best one to use as the four digit number on the chassis will change if you change the chassis while the VIN stays the same.
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Can I suggest that the end of the long VIN number is the best one to use as the four digit number on the chassis will change if you change the chassis while the VIN stays the same. I've just added mine to the list and used the serial number stamped under the driver's seat (948). Given this is an Oct 2013 car this is consistent with the 1,000th model. It's also build number 83448 and the last 4 digits of the VIN are 2017. Somewhat confusing
Red Leader
