4 members (Mogdavid, Luddite, mph, CooperMan), 311 guests, and 38 robots.
+8Rich 95
John V6 52
Posts838,003
rockabilly john
I had a problem with starting my 4/4 4 seater, so had my starter motor reconditioned. Fitted it back on but still had the problem. Went back to the reconditioners with it on the car, and they diagnosed a faulty ignition switch that sometimes worked and then fails occasionally.
Does anyone know what vehicle the ignition switch (where the key fits) comes from on a car of this age and where I might get one ? It has a 'BL' key so I thought it might be a mini, but have searched on the net and not found anything suitable.
Also, out of interest, for future reference, do you chaps know where the starter motor itself comes from as I also had problems buying a new one, hence I went down the reconditioning route. (car has the 1.6 CVH with 5 speed gearbox).
thanks
Matthew
In Original Morgan it states that 1970s and early 1980s Morgans used Neimann ignition switches as found in MGBs and some Vauxhalls. I hope this may help but if not a call to the factory or Heart of England http://www.heartofenglandmorgans.co.uk/cgi-bin/viewPage.cgi?linkName=homePage should.
I believe they may be of the Triumph Herald/Vittess or some form of other Triumph. Hope this helps.
1997 Plus 4, Metalic Blue.
2000 Toyota Yaris. (The Tardis)
It's off an MGB. I recently got a replacement for my '86 4/4 from Gloucester MG Centre, cost me around 50 quid IIRC.
£50 ??!!! Just after posting the query, I called in at Mike Duncan's and he had one - said it was from a Landrover of some sort - and it cost me just under £100 for the full thing including two new keys !!!
Then it took me about 3.5 hours all in to fit the bloomin' thing ! And I had fun wiring it up because two out of 4 wires were different colours to the originals. Still, got it all on and it works a treat now. The starter motor definitely spins faster with the new switch and does not sit there going click click like it did before.
thanks for the info - next time I'll get an MGB one !
Matthew
Hi,
Need to fit a new one to my car too.. Any update on the Land Rover Model they come from... It looks very like this..
http://www.ebay.co.uk/itm/STC981-LAND-ROVER-DISCOVERY-200TDI-STEERING-LOCK-IGNITION-SWITCH?item=380391315485&cmd=ViewItem&_trksid=p5197.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D5%26po%3DLVI%26ps%3D63%26clkid%3D6794160498662242285
Or MGB model for that matter..
Any tips on fitting most welcome. I notice you can buy the wiring separately so you must be able to use the existing one somehow.
Will
Thanks,
Will
Thanks for the timely link. It appears I need one now too, I can't get the key out the lock any more which is a bit of a security issue.
2011 Morgan 4/4
1932 Austin 7 Chummy
Hi,
Any news on fitting....
Question is it the Land Rover one or MGB one...
My one being a 87 car looks suspiciously like the Discovery one..
Will
Originally Posted By DaveW
Yup, that's the badger. Dunno if they fitted different ones after 1986, but that's exactly the right ignition/steering lock for an 86 model 4/4. I suspect they stuck with it until they changed the switchgear.
