2 members (ChrisM, Tresco), 272 guests, and 34 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,088
Page 3 of 4 1 2 3 4
donaldosaurus #204440 15/06/14 01:25 PM
Have you eard cigales ?
donaldosaurus #204619 16/06/14 05:35 PM
Raphael,
are they like crickets or grasshoppers?
I have heard you say "Oh Dear"!!
donaldosaurus #204620 16/06/14 05:42 PM
http://www.google.fr/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCAQtwIwAA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DEeNnfhmrFPo&ei=Sh6fU4_aFsmiO-_bgOAM&usg=AFQjCNEEk4Zhoz4Kdqal1y9vJUDJciTkfw&sig2=sTKXXQEDwW5ngsbWKLT1nQ&bvm=bv.68911936,d.ZWU&cad=rja
donaldosaurus #204627 16/06/14 06:29 PM
They were singing but it is raining since Two days And they are disappear
donaldosaurus #204723 17/06/14 07:57 AM
Originally Posted By donaldosaurus
Raphael,
In English they are cicadas
donaldosaurus #204747 17/06/14 09:09 AM
Here is the rear tyre and sprocket.
Not sure why MMC factory removed the outer edge on rear sprocket.
donaldosaurus #204753 17/06/14 09:22 AM
Good memories
donaldosaurus #204770 17/06/14 10:51 AM
That picture is what this is all about. Perfect.
Ian
Wirewheel #204777 17/06/14 11:47 AM
+1
donaldosaurus #204793 17/06/14 01:12 PM
Donald, that's just a very poor engineering design to be that close.
With your belt just off the inner flange, if you were to "adjust" the rear wheel angle to get the tire clearance in front, the belt would run off to the outside even more.
I can't see swapping out any of the spacers within the swingarm to move the rear wheel squarely over to the right without also causing issues with the belt / sprocket alignment again.
I had a similar situation on my old '76 Harley. It was my fault, but I up-sized my rear wheel from a 3" to a 3.5" and used the stock tire. In my case just the slight extra width widened my tire cross section enough to have the chain rub on the front right in the middle of my whitewall, not a pretty sight.
Have you changed out your rear tire to a larger tire? I think a 175 in width is standard on the M3W.
Dan
Page 3 of 4 1 2 3 4
