8 members (Montegue, TalkMorgan, tezzer, Graham, G4FUJ, RichardV6, CooperMan, JohnHarris, Haggispeed),
349
Posts837,983
Posts: 48 |
Despite a good search I haven't yet found the ODB2 socket on my 2001 4/4. Would someone be able to direct me?
Mark K 2001 4/4 Indigo Blue.
Posts: 2,814 |
Have you had a good grope around behind the middle of the dashboard? Gerry.
Gerry
Posts: 983 |
I eventually found mine below the glove box, between the glove box "floor" and on top of the rubber cover that hides the wires and is attached to scuttle roll bar with cable ties (thanks due to the workshop guys at Melvyn Rutters).
Philip.
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
only mandatory in Europe from 2001, so a 2001 Morgan could easily have been built before the intro date
You might not have an OBD2, only mandatory in Europe from 2001, so a 2001 Morgan could easily have been built before the intro date
Posts: 48 |
Thanks gents, Gerry got it though my wife looked at me a bit strangly when I said I was off to grope the Mog. Easter, they had to comply by May of that year, mine was started in June! But interesting nonetheless. TY
Posts: 1,502 |
I think all the Zetecs (silver top and later) had the Ford OBD2 socket fitted, from well before the EU mandatory date.
Posts: 14,009 |
Mine was impossible to find at first. I had no option but to drop the dash to find it and then discovered that it was trapped between the loom and the bulkhead and so was virtually invisible!
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Mine was hanging down just infront of the under dash trim sheet. Good thing too given the number of times I've had to use it...
Posts: 48 |
Peter, Yes I'm rather glad you did as it was your message that made me visit Amazon and buy the dongle you advised and download the software. So now I have dangling dongle. Thinks 'Must take the Mog to Dingle' - just for the set. Thank you for that.
