Topics49,899
Posts838,028
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Thanks to some precise measurement by Milligoon I have just discovered that Aldermog has cut outs for the speakers already in place behind the carpet lining the footwells.  If you don't have speakers and wonder if fitting them is an option measure up from the floor 9" and forward from the door frame 4.5" and you should be about in the centre of the hole. Dimensions warrented only for a S2 Roadster, but probably apply to all wide body long door cars. So I have no need to cut out the holes. I wonder if there will be speaker wires in place too? To be honest the fitting isn't in the best place, but there are few options. I'm also concerned about the depth behind the panel as I suspect it is very restricted, so limiting the possibility for fitting really good quality speakers because they have big magnets. The next job is to sort out a head unit and tweeters for the dash ends. The buy a load of Dynamat to line the footwells, doors and scuttle/body sides to keep the noise down. This wil be a winter job, I'm sure. Along with the rear toolbox as per Dave Ws description!
Posts: 14,009 |
Open up the radio slot Peter to check for wiring. Not all cars came ready wired up.
Posts: 1,004 Likes: 31
Posts: 1,004 Likes: 31 |
Peter, why considering high end speakers? I am sure wt all that driving noise, no one will be able to hear the difference... Kind regards, BertR
2025 Plus Six - 1909 2009 Roadster 1983 4/4 4str Board member Morgan Sports Car Club Holland ('21)
Posts: 4,896 |
Thanks to some precise measurement by Milligoon I have just discovered that Aldermog has cut outs for the speakers already in place behind the carpet lining the footwells.  If you don't have speakers and wonder if fitting them is an option measure up from the floor 9" and forward from the door frame 4.5" and you should be about in the centre of the hole. Dimensions warrented only for a S2 Roadster, but probably apply to all wide body long door cars. So I have no need to cut out the holes. I wonder if there will be speaker wires in place too? To be honest the fitting isn't in the best place, but there are few options. I'm also concerned about the depth behind the panel as I suspect it is very restricted, so limiting the possibility for fitting really good quality speakers because they have big magnets. The next job is to sort out a head unit and tweeters for the dash ends. The buy a load of Dynamat to line the footwells, doors and scuttle/body sides to keep the noise down. This wil be a winter job, I'm sure. Along with the rear toolbox as per Dave Ws description! Dynamat, all that weight, I thought you were going hill climbing, or is it a drive in the country to Vivaldi
Adrian
Both, Both dear boy! The additional weight is no more than half a tank of fuel and the anti roll bar weighs a hell of a lot more than audio, dynamat and a load of other stuff!
Open up the radio slot Peter to check for wiring. Not all cars came ready wired up. I shall, but to be honest wiring up a radio is something that doesn't worry me, I've done it plenty of times before. I just need to find a switched power supply from the loom.
Peter, why considering high end speakers? I am sure wt all that driving noise, no one will be able to hear the difference... Kind regards, BertR Agreed, but the bigger the magnet the louder the speaker will go without distorting so making listening possible at higher speed. Lining out the front cockpit with dynamat also helps keep noise out, making life easier for the speakers at low to mid speed. Above 60 the audio is fairly pointless.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Mine works well enough top down screens on at 70
Not sure dynamic would be needed with the materials in these cars maybe a little on the ally skin directly behind the speakers would not go amiss but not much else I would think.
Posts: 4,896 |
Both, Both dear boy! The additional weight is no more than half a tank of fuel and the anti roll bar weighs a hell of a lot more than audio, dynamat and a load of other stuff! The heavier it is the slower it is, even though you will have a roll bar (a must) any other weight saving is good. You will find most will remove carpets, spare wheels and anything else that comes off with ease. If you have full bumpers, time to buy overriders. Also more weight means more kinetic energy to stop and get round corners. Hill climbers look for every kilo because in 40-60 second dash it makes a difference.
Adrian
Posts: 859 Likes: 1
Posts: 859 Likes: 1 |
No one ever considers the weight of the driver when talking about gaining extra performance. Perhaps in some cases, a diet would be more effective than some of the solutions one reads about on the net. Of course, I am not suggesting anyone on TM should consider such a solution, but it is a thought.
Neil
Honda S2000 Lexus UX 250h Toyota Auris Hybrid
