3 members (Graham, G4FUJ, dakri, Montegue), 129 guests, and 54 robots.
+8Rich 95
John V6 52
Posts838,013
rockabilly john
sawman Offline OP
These are kinds of fix I can live with, just about within my engineering limitations!
I just whipped the old one out of my brake line and replaced with a shiny new Intermotor 51610 in less than half an hour. Job done, big smiley face grin2
It's a 2004 4/4 btw
Julia
x
It's a 2004 4/4 btw
Have you bled the brakes?
Um, no. innocent
Yes, I know I perhaps should but in my defence I had read up on the change and once the old one was out I lay there with my finger over the hole until my BF had removed the washer from old and put it to the new, then I popped it back in.
I guess less than 2cc of fluid lost, possibly only one, and no sponginess in the system after 200 miles or so. thumbs
Julia
x
The problem lies with the hydraulic switch in the brake pipe. They often burn out as they carry too much current. I confirmed this by sawing one in half and the contacts were knackered.
I fixed it by putting a relay in the electrical circuit. Ideally the relay should have a diode in it and a small capacitor fitted across the hydraulic switch to eliminate internal sparking.
These are the details:
http://homepages.donobi.net/sufuelpumps/Other_Subjects/Electrical/General/Brake_Light_Relay.pdf
More recently it has occurred to me that a more elegant way of dealing with the problem would be to fit LED brake light bulbs as these take much less current.
