Topics49,899
Posts838,027
Posts: 552 |
These are kinds of fix I can live with, just about within my engineering limitations!
Posts: 47 |
I just whipped the old one out of my brake line and replaced with a shiny new Intermotor 51610 in less than half an hour. Job done, big smiley face  It's a 2004 4/4 btw
Julia x
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
I just whipped the old one out of my brake line and replaced with a shiny new Intermotor 51610 in less than half an hour. Job done, big smiley face  It's a 2004 4/4 btw Have you bled the brakes?
Richard 1976 4/4 4 Seater
Posts: 47 |
Um, no.  Yes, I know I perhaps should but in my defence I had read up on the change and once the old one was out I lay there with my finger over the hole until my BF had removed the washer from old and put it to the new, then I popped it back in. I guess less than 2cc of fluid lost, possibly only one, and no sponginess in the system after 200 miles or so.
Julia x
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
The problem lies with the hydraulic switch in the brake pipe. They often burn out as they carry too much current. I confirmed this by sawing one in half and the contacts were knackered. I fixed it by putting a relay in the electrical circuit. Ideally the relay should have a diode in it and a small capacitor fitted across the hydraulic switch to eliminate internal sparking. These are the details: http://homepages.donobi.net/sufuelpumps/Other_Subjects/Electrical/General/Brake_Light_Relay.pdfMore recently it has occurred to me that a more elegant way of dealing with the problem would be to fit LED brake light bulbs as these take much less current. John
