1 members (DJC), 336 guests, and 27 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,088
I have the specs for a plus 8 and wondered if the Roadster alignment would follow the same path. Does anyone know what a Roadster's front end specs are?
2005 Roadster
2013 M3W
MOG South
Given that in 2005 the Roadster still had front springs which are branded Morgan Plus 8 - I think you can take it they are the same.
I should add I just put the Suplex shocks & springs on & the car darts in curves. It's been suggested the Suplex changes the specs from the stock set up.
2005 Roadster
2013 M3W
MOG South
Is the tracking OK? Toe out can cause darting.
And if you've changed the ride height - you may get a bit of bump steer if the track rods are not at the optimum angle.
That's why I'm asking around for the correct alignment. Hoping right toe in would do the trick.
2005 Roadster
2013 M3W
MOG South
