7 members (Davetherave, Paul F, TeddyAds, Chris Cosher, andymog1, cerealsurfer, Graham, G4FUJ),
250
Topics49,908
Posts838,123
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Yes, Lawrie is the man: his comment was "first day back from holiday and you bring me this problem!" I said something about not wanting him to be bored.
The heater quadrant could perhaps be the root cause of the problem: all the time we had the car the heater knob would only turn on 2 clicks. After removing the dash I realised it turns about 6 clicks to the end stop. We'd always through the heater wasn't as good as many said. Clearly it wasn't turning fully on. I suspect blocked by wires...
I hope that they can sort it by the end of the week as I really don't want to be Mogless for the bank holiday weekend.....
Posts: 14,009 |
You are really going to roast!
You are really going to roast! Well it will be nice in the winter! I still have this idea of A/C in my mind....
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Fingers crossed for you Peter that they ring to say it was a loose connector at a terminal block, simple to fix but a nightmare to find kind of job so it's just labour charges.
Posts: 859 Likes: 1
Posts: 859 Likes: 1 |
Peter, I am not sure what you mean by the heater quadrant. Perhaps you could enlighten me.
Neil
Honda S2000 Lexus UX 250h Toyota Auris Hybrid
Neil Assuming you Mog has its heater controls on the dashboard, and not underneath, the silver knob turns a toothed wheel that moves a segmented metal quadrant that serves to act as a lever to pull the bowden cable that opens and closes the water valve to the heater. As you trun the silver knob it "clicks" through a number of stops, to a total of about 6. The quadrant, which is a segment of a what looks like a 3" disc, moves and it seems can rub on wires.
Posts: 859 Likes: 1
Thanks Peter, thats what I thought you meant. Mine moves one click and not anymore. Might have the dash off on Thursday and see if I have the same problem. Hope the Mog recovers from its electrical problems. Neil
Thanks Peter, thats what I thought you meant. Mine moves one click and not anymore. Might have the dash off on Thursday and see if I have the same problem. Hope the Mog recovers from its electrical problems. Neil I know Jays had some issues which resulted in the wires being protected with wrap and tied up away from the wuadrant.
Neil Assuming you Mog has its heater controls on the dashboard, and not underneath, the silver knob turns a toothed wheel that moves a segmented metal quadrant that serves to act as a lever to pull the bowden cable that opens and closes the water valve to the heater. As you trun the silver knob it "clicks" through a number of stops, to a total of about 6. The quadrant, which is a segment of a what looks like a 3" disc, moves and it seems can rub on wires. Peter, I just put a picture of the item in the gallery.
Posts: 14,009 |
Thanks Peter, thats what I thought you meant. Mine moves one click and not anymore. Might have the dash off on Thursday and see if I have the same problem. Hope the Mog recovers from its electrical problems. Neil I know Jays had some issues which resulted in the wires being protected with wrap and tied up away from the wuadrant. I'll try to find the photos I took....they will be similar to Colin's but show the proximity of the flat cable!
