2 members (John V6, Moggo), 320 guests, and 27 robots.
+8Rich 101
John V6 64
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,215
MossyfromNZ
Page 1 of 9 1 2 3 4 5 6 7 8 9
#218405 24/08/14 08:54 PM
Apart from "our Graham" on page 29, has anyone noticed the "Special Edition" on the inside track on the last page, page 114. Is that a forward opening bonnet/hood?
Anyone know about it or recognise the engine?
Ian
I missed G.....must have another look! Ah yes, the final page....quite intriguing and rather naughty of MOG mag to tease us! nono
Drive on the Wild Side
It looks like a Cyclone 3.7 V6 to me, and I suspect it is mounted on a trad chassis, can't make out the suspension too dark. Just behind the bonnet to the top right you can see a pillar which implies the windscreen maybe mounted on the bonnet. thinking
Adrian
How many louvres did it have ? hide
Formerly known as Aldermog
I had a good look at that photo under a magnifying lense and I don’t buy that just because it is a Roadster engine it is “logical” that it is in a trad chassis! Although I don't see any part of a trad chassis you can see that there is a gap under the wheel arch into the engine bay, which suggests it isn't a ful Aero tub. But the sloped bulkhead isn't associated with a Trad and the steering column exists at a strange angle. So what is it? Perhaps an aero tub with a Trad type front end? Stiffer, but less vunerable to accidents. No doubt we shall see.
I’ve long felt that a V6 Aero would make a lot of sense. After driving a full V8 Aero I’d never buy one, or the new +8, simply too much power and noise. But V6 Aerolight Coupe? Now that could be both stunning and a winner!
But I culd be very wrong...
Originally Posted By Aldermog
I had a good look at that photo under a magnifying lense and I don’t buy that just because it is a Roadster engine it is “logical” that it is in a trad chassis! I don't see any part of a trad chassis. Also the sloped bulkhead isn't associated with a Trad.
I disagree, I did not say trad chassis because of the engine, if you look carefully behind the brake, there is a black box section that looks just like a trad chassis rail without the internal wing panel fitted to it. If it is designed to be a new model then I suspect that MMC would want a cost effective and easy to build car and the proven chassis would be the obvious choice, also the Aero chassis is not cheap or the running gear. But I might be wrong.
Adrian
Well it certainly looks different. The firewall seems very high to me.
You are right, I missed that.
So we have an Aeroesque body, possibly a drop head coupe, based on a Roadster. I wonder if it has an Auto box.
I have not yet received my copy. Can you see any of the suspension components? Is it possible that it is an entirely new chassis?
This is very frustrating - not being able to see the photo in question.
Giles. Mogless in Paris.
