2 members (Black Adder, Luddite), 210 guests, and 26 robots.
+8Rich 96
John V6 51
Topics49,900
Posts838,037
Page 5 of 7 1 2 3 4 5 6 7
Hello Smaug.
Returning to your original question, the answer is "nervous".
Originally Posted By MO63WLR
You can upgrade 'most' of it to current spec, at a cost of course.
At a high cost, yes.
Stig
U
TM Photographer of 2008
U
Originally Posted By Smaug
Wow !!! ....these specs are indeed frustrating having bought (not knowing) a 2013 model a month ago :o(((
Cheers,
Smaug
Is there a price difference between a 2013 and a 2014 model? If so, did you pay the 2014 price?
Ken
Smaug Offline OP
My dealer only had one MTW which I bought, cant tell if the price would be different from 2013 to 2014...but seeing your point, I don't think he tried something bad. Just would have been nice to tell me that the car was from 2013 sick2
Cheers,
Georges
Smaug Offline OP
@ P Dron...Na!, just dont want to have it more in repairings than on the road and frustrated to not having had the knowledge to buy (order) a 2014 model.
Just one thing is clear to me: I absolutely want to ride a 3Wheeler, it is an fantastic car!!!
cheers...
Cheers,
Georges
My 2014 upgrades were rather expensive, the NVH IMHO was a waste of money.
The steering comfort pack is simple and relatively inexpensive. The Cooling mod I found worthwhile.
I did Centa while it was at factory as Compensator had died.
Smaug Offline OP
Hi Donald, that sound interresting...
- Centa in my opinion is a must
- Steering comfort pack also
- NVH, if the previous version is reliable, just for the noise not really needed
- Cooling Mod no need, I'm not often in traffic...
- What do you mean by IMHO?
any suggestions welcome listening
could I ask you what the aproximative costs will be for the different upgrades? listening
Cheers cheers
Cheers,
Georges
IMHO = In My Humble Opinion.
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
Cooling fan or fan diy is a necessity
Z
Z
@ Aldermog & Red3W
here are some Pictures of my beauty (hope it works)
2014, number 877, 1150 km on display, SuperDry Edition with modified Stickers...
Knowing what I know, seeing what I've seen and in consideration of your "877" number...if I were you, I would drop what I was doing right now and run (not walk) go change the Bevel Box lube. Don't assume anything other than the worst. Any damage done due to lack of lubrication is irreversible. The Bevel Box doesn't stand a snowball's chance in hell if it has the infamous goop in the box. Even after reaching high temperatures, the goop won't flow and it will starve the bearings and gears of lubrication. On my box, I measured temps in the 240-250*F range which is 30*F higher than what was measured on the engine's crankcase. I was able to lower the box temperature by 90*F by flushing and changing lubes...but it appears it was too little, too late on mine.
http://www.talkmorgan.com/ubbthreads.php/topics/210338/1
As a new owner of a M3W, you are about to embark on a great mechanical adventure. Dust off your spanners and proceed with caution. And just forget the fact that it is a new car.
This is the result of numerous lube changes after the "goop" was discovered...in M3W No. 859.
Don't go by any databases, range of M3W numbers or suspected build dates as no one (including Morgan) knows what's in your ride. On a compensator issue on my M3W, Morgan had no idea of what compensator I had, if it was fitted with a grease zerk or not or if the bell housing had been "hole sawed" or not by their records. Quaife (manufacturer of the Bevel Box built specifically for MMC) builds good products but no gears/bearings stand a chance of lasting without lubrication. Like most here, anything that is running gear lube isn't high on my priority maintenance list until I get quite a few miles on it...not the case here.
After dealing with these totally un-necessary issues (created by trying to cure a problem that wasn't really a problem to begin with), I wish my M3W looked like this under her skirt...
Z
