7 members (AlyMatt, piquet, +8Rich, BobtheTrain, TBM, GrumpyPa, PaulV),
247
49
Posts838,002
Posts: 4,896 |
Welcome. There are quite a few about in your budget, take your time one will find you.
Adrian
Posts: 1,337 |
Welcome and do not go near Williams if the spaniels are about because there is a good chance that you will spend more than you wanted to and end up with a car that will delight you but is not what you originally had in mind  Pete
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Welcome and do not go near Williams if the spaniels are about because there is a good chance that you will spend more than you wanted to and end up with a car that will delight you but is not what you originally had in mind  Pete +1!!
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
Welcome from "downunder" and good luck with the search
