5 members (Dinko, sprinty, JMcL, Luddite, uvk33n), 314 guests, and 40 robots.
+8Rich 102
John V6 64
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,916
Posts838,221
MossyfromNZ
Looks very interesting!
Jaguar F-Type V6s roadster
2009 Harley Davidson XR1200
1986 Honda VFR750F (RC24)
"right now I am struggling to think of another car maker who still uses a rigig driven rear axle. They all seem to have gone irs or front wheel drive or both."
Funny you should mention that, I have a 3 year old, modern vehicle with a solid back axle on cart springs - my Toyota HiLux pickup, Mitsubishi L200 also uses a solid rear axle, and possibly Ford on the Ranger and VW on their new pickup may have a solid back end. It's all a matter of lateral thinking. doh
Very interesting to see the CAD design Brian and good to know that the factory, aided very much by you, by the sound of it, are thinking about a modern version of an old problem.
The racing V8 Commodores used a Watt's link system and sometimes very sophisticated variations.
Rigid rear axles are quite common on 4x4 type vehicles and also on light (and heavy) commercials, especially in developing countries. Morgan axles, as far as I am aware, are made in Australia by a factory owned by Dana - a large US parts supplier. They incidentally also now own the factory in Birmingham where the GKN axles were made. They also have plants in USA, Mexico, Brazil, you name it.
These axles are relatively easy to adapt to different customer requirements - the lengths of the axle arms and half shafts are simple to make to the required size to get the track you want. Spring brackets and other bits and pieces can be welded on as needed.
Rigid axles will be around for a long time yet!
Fjemog
1993 Plus 8
So, there are now two versions of removable (i.e. return to standard) 5 point rear suspension systems.
Waiting for full info. to appear on the other system... smile
Green & Grown Up
Green & Grown Up
As always, being the 'Daft Laddie' doh and not the 'Engineer', I will ask the Question I once asked in another 'Rear Suspension' thread a couple of years ago it seems.
Has no one ever added a 'Spring Over Damper' to their weak Leaf Spring Rear Suspension, and if not, Why not ?
idea
Aeroman Offline OP
Although the CAD drawings are shown in a static position Adrian, on the computer the axle can move through its full arc and thus I think your concerns have been allowed for.
Originally Posted By Aldermog
I've long thought that a set up of this sort is "the next step".
There is nothing wrong with a well sorted rigid rear end, IRS is better but far more complex and expensiveness and in many respects would spoil the character of the MOG. I'll bet that with this rear and a Suplex front the Roadster rides and handles remarkably well!
Although I had the Suplex suspension and the Rutherford AVO's fitted to my Roadster, the 'mule' was running standard Morgan front suspension as regards springs, and with the rear end secure the front also seemed to be less of an issue.
As regards the provenance of the rear axle, I'm sure someone mentioned that it was manufactured in Malaysia, though at whose OE instigation I don't know. Maybe it is off a baccy, next time I'm in the factory I'll ask them Paul?
Brian
2014 Morgan SP1 (Rocket Red)
Seems like we will have to wait for an in depth report on the rear suspension but if it works how it appears to and is available at a reasonable cost as an retro fit I think there will be a significant number of takers, including me.
There may shortly be many trad owners thanking Brian for specifying the SP1 rear suspension in the way it has been.
Andrew
'Alice' 2013 Duratec Plus 4. Pearl Blue
When the SP1 drives by- not sure that people will really be talking about its axle?
Let's just look at it again!!
Porsche 981 Spyder
V8 Speedster ( 5 years)
4/4 Competition spec (5 years)
4/4 4str Kent ( 10 years)
I maybe wrong but doesn't the fastest accelerating production car have a live axle?
Ford Mustang Cobra Jet 2010!
From Wikipedia "A drag racer took his completely stock car and recorded a 0-60 of 1.52 seconds and a 0-100 of 3.26 seconds, and made a 1/4 mile pass of 7.848 seconds @ 174.4 mph, crowning the Mustang Cobra Jet as the world's fastest production car, smashing the Bugatti Veyron and Ariel Atom V8 by nearly a full second in both categories."
I have driven the mule and would have put the new suspension on my roadster rather than the suspension upgrades I fitted to my Roadster.
IMO designing an IRS system would need a different chassis as the strongest part of the chassis would need secure the diff or require adding so much weight to a trad chassis it would negate any benefit.
Morgan +8
Morgan Club Sport
