Morgan Aero 8
10 members (JohnHarris, B3MOG, mph, Whizjet, Alistair, chanteclair, James B W, Julian BB, Wouter, bmgermany), 197 guests, and 35 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,042
#22748 19/10/08 09:03 PM
scottie Offline OP
does anyone know the correct way to open the engine covers. i keep breaking the pins. do you open the front or rear catch first.
kin Offline
You brke the pins(engine latch?) How did you manage that? shocked2
scottie Offline OP
put too much pressure on them, they are very tight. i have broken 2 already tried 2 open today to fit an optimate on the battery but couldnt open. i was frightened to put too much pressure incase they broke again.
kin Offline
I always open the back one first...
kin Offline
I think its a case of getting the hang of it...
I was really struggling with it at first,especially the front catch, but once you mastered the technique, its a doddle.
Sounds like you have (or more likely someone else) has over tightened the inner side of the latch...
The springs are not too stong as long as the mechanism is not over-tightened.
Try loostening the nut on the inner side of the wing where the spring is and testing the slide... if it's too stiff you've gone too far tightening it up.
Weird. I open the backward first, need to use my two hands though.
Hello all
I was told by a Morgan dealer many years for my +8 to do rear catch first (closest to driver) then front catch.
Suspect recommendation would be same on Aero.
Cheers
Philip
ps whilst on subject of bonnet opening any idea if anyone has or is close to producing a stainless steel strut support kit? I currently use two 1m lengths of round doweling to support bonnet open!
Philip
1985 Plus 8 four seater
Malone F1000 - track car
There is a kit.. although off the top of my head I can't remember who makes it...
You have to bend to your car same as the trad version.
CRT has some if he pops in.. might be Simmonds or from John Worrell.
Phil Egginton
1979 4/4 4 seater
