0 members (),
313
32
Topics49,897
Posts838,017
Posts: 849 Likes: 2
TM Photographer of 2008 Talk Morgan Regular
Posts: 849 Likes: 2 |
Has anyone had a failure of the weld holding a retaining catch to the header rail. If so, how do you separate the hood fabric from the header rail to enable rewelding?
Ken
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Has anyone had a failure of the weld holding a retaining catch to the header rail. If so, how do you separate the hood fabric from the header rail to enable rewelding? I think that is not an easy DIY option but needs specialist attention: where are you in the UK? There are a number of dealers with good trim shops who can do it.
Posts: 14,009 |
I believe that there was a posting about this a couple of years ago...by DaveW?
Posts: 681 |
Has anyone had a failure of the weld holding a retaining catch to the header rail. Yes, me. Took it to Allon White in Cranfield who brought in a specialist TIG welder. Now better than new.
Posts: 849 Likes: 2
I believe that there was a posting about this a couple of years ago...by DaveW? Thanks! I've had a look but couldn't find it. Taking out the rubber seal should provide a clue.
Ken
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
It wasn't me. I do remember the post though.
Posts: 849 Likes: 2
Has anyone had a failure of the weld holding a retaining catch to the header rail. If so, how do you separate the hood fabric from the header rail to enable rewelding? I think that is not an easy DIY option but needs specialist attention: where are you in the UK? There are a number of dealers with good trim shops who can do it. Detach the side arms, remove the rubber seal, take out 11 wood screws and it's off!
Ken
