3 members (Zach, DCH, sezznowt), 227 guests, and 29 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,147
Page 4 of 4 1 2 3 4
Rog Offline
It would be interesting to see the effect of adding some phone key pad protection material to the front faces. It may just be enough of a thermal insulator to stop the dew point occurring on the inside. Double glazing!
Roger
my problem is with the sun's heat sunny
a part of the digital numbers disappear and come back when the temperature is not as high.
I have maybe only drive in winter snow
Alpine regards
Morgan 4/4 Sport 2012
Mini Cooper S 2017
Morgan 4/4 70th Anniversary 2006-2015 prev
CBY Offline
The procedure to remove mist on the windscreen of your "normal daily" car fitted with air con is to switch on air con and blow cold air. Cold air contains less water than hot air. If you blow hot air in a first time you increase the mist.
During driving a Morgan, in order to avoid mist on the instruments perhaps they have to be cooled.
I have the same problem on 2 instruments: oil and petrol in winter. "They all do that..."
Check also if there is no leakage at the T piece of the windscreen washer. This is close to the instruments and it can increase the humidity by splahing water all around. Generaly you see see the water falling close to the gearbox lever. An other "They all do that..."
Regards
2005 PLUS 4
I've done that Roger (plastic film on the front). It's still there, is undetectable, but doesn't make much difference.
Rog Offline
Dave, I think the theory is ok but the film is perhaps too thin smile
Roger
Page 4 of 4 1 2 3 4
