3 members (RedThree, Morganmike, SailingTom2), 232 guests, and 27 robots.
+8Rich 96
John V6 52
Topics49,897
Posts838,018
Page 2 of 7 1 2 3 4 5 6 7
Rich Welcome! We even had Morgans in the US. There are lots of models to chose from depending on budget, needs and desires. Some locations are also limited but in the UK you should have it all. The folks on TM are very well versed and should be able to steer you in an appropriate direction.
This timeline might help http://www.talkmorgan.com/ubbthreads.php/topics/232670/Morgan_Model_Timeline#Post232670
Cheers,
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
Welcome Rich
Did my degree at High Wycombe so it was home for 3 years
Lived in the house in Desborough Park Road where Munir Hussain (our landlord) beat up his assailants, and went to prison.
still have some very good friends that live in Sands and often visit - not taken the Mog yet
Welcome to the forum Rich. Good luck for your search.
Ian
Black Rat
Black Rat
Like this one !
Keith
2013 narrow bodied + 4 Ruby.
RichB Offline OP
Thanks for the comments - Burgandymog, your narrow body +4 looks really good. Made me think and investigate 'narrow bodies'.
I may have a clearance problem to get on our drive so my understanding that a 4/4 or a narrow body +4 with slightly better ground clearance (correct?) may be better bet for us. Will have to try before I buy as getting a car and finding it won't go up the drive would be slightly embarrassing.
+4 GDI Connaught Green, 2014
Magnolia
The standard tyres fitted to a 4/4 give 16mm more ground clearance than the standard tyres fitted to a Plus 4. If ordering a new car I'm sure wheel and tyre sizes could be specified to give you maximum ground clearance if you need it. I still have the 195/60 tyres on the Plus 4 and we sometimes touch on the peak of the driveway going to our underground garage. Fitting 195/65 would give 10mm more clearance.
Welcome from sunny Sydney, Australia sunny
Black Rat
Black Rat
My car has 185/70/15 and is about an inch and a half more ground clearance than standard I believe.
Keith
RichB - bear in mind that all current cars have wider rear track than front track - up to five inches, so don't get caught out as I nearly did. Measure across the rear wheels for a true width.
Formerly known as Aldermog
I got caught ordering a trailer to rent, as DW says they have wider rear ends...
Maximum Width stated on the MMC Website:
4/4.........1.630m
Plus 4......1.720m
Roadster..1.720m
Plus 8......1.751m
And to Compare,
Golf 2015....2.027m
So they are all "slim", but some more than others!!
