3 members (Carbuilder, JoeSpeetjens, uvk33n), 297 guests, and 33 robots.
+8Rich 96
Luddite 54
Topics49,904
Posts838,083
Fossey Offline OP
The rabbit's running with George at Powerlite as I've sent some photos of the old unit. As it appears to have been built in 1989 it is probably due a change!
As for earthing I got a 3.5m length of nice thick cable to earth the battery to the same point as the engine earth - a Northampton Motorsport recommendation when I got the engine remapped.
1990 Plus 4 4 seater
Ivory with Red
Fossey Offline OP
Well case solved - its a starter motor for a Leyland Sherpa van. LRS713. No one seems to do an uprated version - can't for the life of me understand why - is there no Sherpa racing? So had to resort to the NOS route. Fitment due when its not freezing/pouring with rain.
Ivory with Red
Black Rat
Black Rat
Fossey, when it's fitted if it still doesn't spin up fast enough consider the trick we used with the FX4 Taxi which was notoriously difficult to start in winter. If you can find room fit two 12v batteries wired to provide 12v but double the amps.
Keith
2013 narrow bodied + 4 Ruby.
I was thinking along parallel lines.
Best Regards
Lang may yer lum reek
Ohm my god...........
Turn the Amps to 11.
Best Regards
Black Rat
Black Rat
Watt are you guys saying ?
Keith
Fossey Offline OP
Well case well and truly solved. New starter motor LRS713 and the damn great earth wire to the front and the car started first pull on the frosty Saturday morning.
So now for:
a - some driving
b - some serious ungraditis - spotlights and a nice discrete dash without the acres of plasticware.
Ivory with Red
Fossey, great result.
Ian
