Topics49,899
Posts838,024
Posts: 5,587 |
3 inches below top of screen so unlikely !
Posts: 5,587 |
Posts: 381 |
Have no sun visors on my Mog , how on earth do I get some and avoid drilling holes in the windscreen ! I made 2 removable sun visors with perpex. They are fixed with 2 suction cups whose origin are from kitchen towel hook. I drilled 2 holes at each end of the perpex, the suction cups go through. You can stick them at variable height, and remove them after use. I use them temporaly in the evening when the sun is very low and just in front. Not very beautiful but efficient.
Regards 2005 PLUS 4
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
This is how mine look. The brackets are wrong way round and the visors are semi-immobile.
Posts: 1,502 |
Sun, in Scarborough?
I use a peaked cap - note, not a flat cap!
Nigel
Posts: 5,587 |
This is how mine look. The brackets are wrong way round and the visors are semi-immobile. Top quality stuff there Dave ! Excellent !
Posts: 381 |
DiY, both side  Can be stored under the seat.
Regards 2005 PLUS 4
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
Personally I use all options, sun visors, polarised Ray-Bans, and tweed flat cap (never a baseball cap, thank you).
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
tweed flat cap (never a baseball cap, thank you). Chapeau !
Posts: 5,587 |
Personally I use all options, sun visors, polarised Ray-Bans, and tweed flat cap (never a baseball cap, thank you). Yes , agreed on headwear , its got to be proper gear or nothing !
