5 members (IcePack, Jon G4LJW, DJC, James B W, Socalm3w), 190 guests, and 38 robots.
+8Rich 95
John V6 52
Posts838,002
rockabilly john
#239059 09/12/14 11:54 AM
E
EGSmog Offline OP
E
A somewhat trivial alert but nonetheless a nuisance. The tubulars that support the front bumpers have upswept support bars with a clamp at each end when loosened the supports can be adjusted in order to raise or lower the bumper slightly. Looks like a simple clamp at the front end until one loosens the clamp bolt and inserts a screwdriver in the gap to "spring" the clamp. Whereupon the clamp splits apart into two broken bits. It turned out to be a casting and it certainly wouldn't spring. My problem was primarily caused by the assembly having been powder coated which increased the adjacent tube thickness.
But watch out - a seemingly simple job bites back.
Thank you for that. I haven't got that far in checking my valance fitting - maybe time for not moving those parts!
