3 members (TalkMorgan, verysideways, IcePack), 333 guests, and 34 robots.
+8Rich 95
John V6 52
Posts838,014
rockabilly john
Page 2 of 6 1 2 3 4 5 6
frunni #239364 10/12/14 08:41 PM
Formerly known as Aldermog
It does seem the metal/plastic radiators used by MMC were not of robust enough quality.
When they go it seems plastic fails and all the water dumps....
Not good enough, a rad should last 15-20 years, but there isn't a lot we can do.
Are the new MMC rads better? Who knows?
But if I had to replace a rad I suspect I'd replace it with a MulFab item....
frunni #239369 10/12/14 09:00 PM
Ray Offline
I was told that alloy rads age with the constant heating and cooling ?,resulting in cracking is this true? anybody know.
frunni #239387 10/12/14 09:50 PM
Ray when i was in the services a lifetime ago i remember we had to check for loose currents when fitting large alloy rads with multi testers or corrosion would occur,we can discuss the merits of an alloy rad with our metalagist friend at the next meet sospan likes to talk technical
Ray Offline
Em good idea. thinking :santahohoho:
frunni #239415 11/12/14 07:15 AM
frunni Offline OP
Hello again,
Thank you for your answers and suggestions.
I've already heard and read about the Mulfab radiators.
But I wanted to know whether it is possible to repair this angle piece or if someone has an idea how it can be repaired.
My local dealer already told me to that I would have to change the radiator. But thats the expensive solution.
So if the repair can't be done, I will have to change the radiator but I wanted first to try perhaps another solution.
V6 Roadster black 2009
frunni #239423 11/12/14 07:59 AM
Had a similar problem with a BMW 740i. Found that in the USA it was possible to buy a kit with the plastic elbow for a few dollars, while over here there was no sign of such an option.
I ended up replacing the radiator because of time pressures!
frunni #239490 11/12/14 12:59 PM
frunni Offline OP
Hello,
This morning I spoke to a kind mechanic from a german dealer.
He explained me how the plastic elbow could be repaired and he even sent me some photos.
They encountered this problem several times.
So I'll try my best to do the repair.
frunni #239518 11/12/14 03:46 PM
Excellent news Frunni.
I hope you have it repaired soon at reasonable cost. :xmascheers:
frunni #239555 11/12/14 05:21 PM
Perhaps you would share the photos and instructions for the repair -- You never know when a fellow Morgan owner might need them!!!!!! -(hopefully not me!!)
Robbie
2021 Plus Four -- Helga
211-WX-1433
frunni #239696 12/12/14 09:29 AM
frunni Offline OP
Hello Robbie
Yes I can do that. But then I have to translate his answer into English.
Here I'll try: (Without warranty)
You have to insert 2 flat screwdrivers on the places marked by the 2 red arrows on the first picture.
Do not insert the screwdrivers on the place marked by the green circle.
You have to do this carefully. It needs some pressure and force to do this. When done correctly the upper part will pop off.
On this upper part you can see a rubber sealing ring (or is it gasket?) that has to be replaced. He writes that you can try to insert a sealing ring that is 0, 5 mm thicker than the original one.
He also says to re-enforce the 2 big hose fittings by inserting 2 stainless steel rings. The hose fittings often break when the hose clamps are tightened too much.
(On the pic you can see the left one). The stainless steel rings must fit correctly.
They always do this when the radiator is demounted.
I hope my translation is not too bad and it helps together with the pics.
But as I said: Without warranty and on your own risks.
