2 members (MATTMOG, DCH), 276 guests, and 30 robots.
+8Rich 94
John V6 49
Posts837,994
rockabilly john
Page 2 of 8 1 2 3 4 5 6 7 8
PaulJ #243608 01/01/15 06:50 PM
X-Wedge engine could V4 with flywheel end of the crankshaft would be better cyclically, the damper clutch disk would be sufficient, mounted with no electronic throttle cable as polaris sling (rpm rocket) that has apparently ECU problems I would not want to end up like a pebble in a slingshot.
PaulJ #243616 01/01/15 07:12 PM
Thanks Matty, will check the retainer bolt before I venture out. Do you have any sign of water ingress with the cooling kit installed?
I know what engine and drive train I would fit. innocent stirpot
ENGINE
Type
90° V-twin engine, 4-stroke, 4 valves, double ignition
Cooling
air and oil with an independent cooling pump. Oil radiator with thermostat controlled fan.
Engine capacity
1380 cm³
Bore and stroke
104 x 81.2 mm
Compression ratio
10.5 : 1
Maximum power
71 kW (96 HP) at 6500 rpm
Maximum torque
87 ft-lb - 120 Nm @2750 rpm
Fuel supply / Ignition
phased electronic Multipoint sequential injection, Magneti Marelli IAW7SM; “ride by wire” Ø 52 mm throttle body, IWP 243 Magneti Marelli injectors, double oxygen sensor, integrated management of 3 engine mappings, traction control, cruise control
Starter
Electric
TRANSMISSION
Gearbox
6 speeds with final overdrive
Final drive
double cardan joint and fixed bevel gear seat
Clutch
single-disc with integrated anti-vibration buffer
Red3W #243675 01/01/15 11:24 PM
Interestingly none whatsoever and I have been washing the old girl an awful lot also. It all gets so warm I think any water evaporates. No sign of any dirt either
PaulJ #243717 02/01/15 10:47 AM
The very modern Guzzi engines are fantastic. But they have a massive cam cover running right up the front of the engine.you cannot see this on the bike ...but in a MOG it would be on display and IMHO would not look very pleasing.
You can see these on Trikings.
Not sure how the offset drive would work either?
Neil
PaulJ #243719 02/01/15 11:05 AM
What about a reverse???
Robbie
2021 Plus Four -- Helga
211-WX-1433
PaulJ #243755 02/01/15 02:10 PM
Well, you have clearly put a good mileage on yours with the cambelt cooling upgrade Matty. No water or dirt ingress, using over the winter, I think you have tested it enough for us to go with the gap. I think I shall get mine all spaced out for 2015.
NeilL #243771 02/01/15 03:22 PM
It is actually the belt cover for the alternator which sits between the cylinders. It could easily be replaced by a polished alloy cover (££ Option?)
Early 1200 California engines do not have this cover and the alternator is on the front of the crankshaft.
The final drive from the gearbox is offset to clear the 200/60 R 16 rear tyre.
Triking and Aero Cycle Cars use a small reversing gearbox as part of the final drive. Alternatively an electric reverse can be used.
I suspect the total package that would be required from Guzzi may be somewhat more expensive than the current engine, gearbox etc. But it would certainly vibrate less and be more reliable.
PaulJ #243836 02/01/15 05:50 PM
Interesting. Is there a Triking vs M3W test published anywhere? I'd like to see them compared.
2010 Morgan +4
2014 M3W Brooklands
To be raced
PaulJ #243840 02/01/15 06:02 PM
I do not think there is. A bunch of us visited the Trikings "factory" last summer.
There were some interesting variants there...developed over the years. They were v interested in my M3W. Not sure a Triking would be my thing ...but they do produce a v nice kit car.
Neil
