7 members (GrumpyPa, Deejay, Socalm3w, RichardV6, sezznowt, Pittsartist, Mike D), 360 guests, and 83 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,759
Page 3 of 7 1 2 3 4 5 6 7
lol
Fixing broken sh1t
South Wales Correspondent
Jim,
What's the old phrase- 'be careful what you wish for.' Up until last year, I'd never had a spare wheel off a Mog nicked either. Come the summer, mine disappeared in a hotel car park.
Still, it was a conference full of laywers, so what can one expect?!?*
GLLHG
You might have lost the whole car if it had been a conference full of bankers at a pensions convention rofl
True, very true! hide
GLLHG
Gerwyn,
You were perfectly safe -- Bankers only hold such conferences in 5Star+ hotels in exotic locations (not that S.Wales hasn't a hint of the exotic happy3 hide
Happy Christmas!!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Hi Robbie,
South Wales is wetter than West Cork today!
I can identify with your observations. Several years ago, I did some training seminars for Bank of Ireland- five days in the Killarney Park Hotel- real breadline stuff!!
I have to go to Cwmbran later today, so if I get chance I'll say hello to the guys at Newtown for you
regards,
G umbrella
GLLHG
Originally Posted By minikeefy
Nice work Dave...I think you ought to be more concerned over other Morgan owners stealing your cover now!!
wonder what the spanner size is, metric I guess, 10 mm or 12.?
Originally Posted By Sukram
Why change a wheel, never had a flat tyre
You've been lucky then!
Particularly with the ever increasing amounts of debris left on the roads nowadays... scared
maybe Morgans should use run flat tyres, but they give a hard ride to an all-ready firm suspension.
DaveW Offline OP
It's taken 18 months to get around to making a spare wheel protector for Mr Bumble. But cold winter days offer a good opportunity to get on with jobs like this.
The first job was to dig out some stainless steel. The dimensions are shown. I had to shave a few mm from each long edge while fitting - no more than 4mm each side. The U bolts are 42mm.
This time I drilled through the U bolts instead of using C brackets inside. This is a much neater solution. Cutting oil makes the job much easier when drilling stainless steel.
This is a test fit over the baseplate.
Here's the finished cover. Lined inside with 4mm neoprene, and edged with U channel, mitred on the corners and fixed with superglue. I expected it to be shiny but when I stripped off the protective cover - it was satin finish!
Here's the baseplate with pilot holes drilled. This offcut came from Newark Autojumble, and was 70p for a length three times as long as this. The remainder is in one of the earlier photos.
Here's the completed baseplate. Slotted so that it can be fitted without removing the T bar. The holes are very slightly off position, but not enough to matter.
I need a bench drill! smirk2
Test fit and all is well.
And that's another job done. thumbs
Note that this slightly protrudes into the space where the sidescreen bag fits. On the Roadster, due to the deeper spacing it doesn't intrude at all. Here though, it may be a tight fit to get the sidescreens in. We'll see.
On my car there is a grub screw that locks the spinner.I think it's between 5–7 mm.It goes through the boss and locks onto the spinner. Not fully foolproof but does improve security. I keep the Allen key tucked away for easy access.
