8 members (Image, RichardV6, Graham, G4FUJ, sewin, Dinko, B3MOG, James B W, Strathaven), 250 guests, and 21 robots.
+8Rich 99
John V6 55
Topics49,908
Posts838,114
numog,
because of the different opinions that I've seen i decided to look myself..
This is at least the label which is on the axle of my roadster 3.7, manufactured in Summer '14.
Since you have the same car, can you check on yours?
The first gear is close to useless, I start in 2nd, from there it fitts.
Ex-Roadster 3.7, now P6
Well - photo not taken from MY car, but at the factory...
But i´m sure mine has the same diff fitted!
drive 2015 Roadster 3.7
That leads to the question:
Do I have the right axle?????
Are they just using what's on top of the pile?
..well - don´t hope so, but face it! scared
imho - no. hide
Numog,
when has this picture been taken?
What year is your car?
You can check the ratio by marking the wheel or brake drum, and the propshaft UJ. With the gearbox in neutral, and the car jacked up safely, note where the propshaft UJ starts - easier from the 6 o'clock position. Then slowly rotate the wheels. Make sure that both wheels turn at exactly the same rate - you may need a helper. 3.07 is only a shade over 3 revs. 3.70 is closer to 4 revs, so 1 revolution of the roadwheel will produce either 3 revs of the prop, or nearly 4.
Not all Roadsters have had the same axle ratio. It depends on the gearbox, and whether top gear is direct drive 1:1 or overdrive (0.85ish).
From memory......the S1 had a direct drive top gear with a 3.07 diff.
The S2 and S3 had an overdrive top gear with a 3.7 diff.
I don't know what the ratio is of 6th gear on the current box, but 3.7 could well be the right ratio.
According to my 2015 hand book
5th gear 1.00
6th gear 0.74
Checked my car today on the Dave W test and both wheels turn together so must presume LSD.
With 16" wheels my speedo seems pretty good but the recorded miles is about 10% less than it should be.
Regards david
,,BSA Goldstar,Honda CB1100R. Jaguar FTypeS Porsche Cayman S
Dave, thanks for the advice.
That is the logical next step. But I will let the dealer do that in my presence. Things start to make sense now: The speedo is showing numbers 20% to high, that's about the difference between 3.07:1 and 3.73:1.
Morgan said, the can't correct the speedo, there is no mistake. Someone fitted the wrong axle.
3.73 is the ratio of the 4/4, without limited slip differential (to avoid the misleading term LSD).
I thought the 4/4-axle is a lighter version, the one installed looks exactly like the Roadster axle.
We will see.
